Dodgy keyboard key (just the one!)
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Acer Aspire 5735Z.
Right cursor key has stopped working. It did this a while ago and then, for some inexplicable reason, it started working again. It's now stopped - AGAIN ::b
It's not a hardware fault and this has been reported across the interweb as a common problem but there seems to be no specific solution for my model (all the answers give you help to get around the issue but I want the actual key to work).
Running Windows 7
Any idea? :dunno:
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Re: Dodgy keyboard key (just the one!)
Post by BillyGoat »
kellys_eye wrote:Acer Aspire 5735Z.
Running Windows 7
Any idea? :dunno:
Not hardware? Sure about that?
Turn PC on and enter BIOS as soon as it comes on (F2, Delete, whatever it tells you). If it's NOT software, you can use arrow key to navigate.
If it works, it's OS related. If it don't, it's hardware - simple.
Try take KB off by disconnecting ribbon, attach. That's about your lot. Wouldn't be the first hardware fault to be common across a range.
BG
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Post by wine~o »
BillyGoat wrote: Wouldn't be the first hardware fault to be common across a range.
BG
Especially on an Acer Aspire.. I had one..once.
BillyGoat
Troll Headbutter
Post by BillyGoat »
Built to a budget WO.....not typically a high end machine.
Also, if you think it's typically Sainsburys/supermarket quantity of sales (where did you get it? They 'fell out' with a certain retailer a while ago), then you'll hear more faults as there are TONS of them out there.
BG
kellys_eye
Well it would appear that it's a hardware fault as the cursor key doesn't work under the BIOS screen :roll: - thanks for the tip BG - but funny it should suddenly work (for abot 3 months) before stopping again :scratch:
It's not worth the effort of taking the keyboard apart (if it's a broken track - probably a pth breakdown - I could fix it easily) but other than this issue the lappy has worked flawlessly. It's actually quite speedy! Ah well, if I get bored over winter I might have a closer look at it.
Cheers :thumbright:
BillyGoat
Troll Headbutter
Post by BillyGoat »
moderator6
UHM Super Moderator
Has thanked: 141 times
Been thanked: 362 times
Post by moderator6 »
Funniest ebay ad for ages:
PLEASE CHECK THE PICTURE OF THE KEYBOARD THIS IS THE EXACT ITEM THAT YOU WILL BE RECEIVING
A 100% Compatible model will be sent if the exact part number isn’t in stock
:lol: :lol: :lol: :lol:
Return to “Computers”
