help??????????????????????????????????????
Locked
Stufran
Post by Stufran »
ive been at this all night and im too tired to work it out for myself
just replaced a strip light with two light fittings
light fitting 2 is spurred off light fitting 1
light fitting 1 has the switch
light fitting 2 is always on?
light fitting 1 works off the switch?
im sure its something simple but please advise before i kill the wife
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
when you connected light fitting no.2 to no.1 you connected it wrong.
you have connected the no.2 live to the "looped-in" live feed in fitting no.1
take it out and connect it to the "switched" live of fitting no.1
simpleplumb
Post by simpleplumb »
As above but you could also get rid of the wife as she probably distracted your attention while you were deep in concentration.
Stufran
Post by Stufran »
thanks guys, you've saved a life tonight
Rich-Ando
Pro Tradesman
Post by Rich-Ando »
Stufran wrote:thanks guys, you've saved a life tonight
lool no problem :thumbright:
Locked
Return to “Lighting”
