I spent most of Saturday sealing the pattern imprinted concrete drive. This is the second time that I have sealed it in 12 months. A mate of mine installs PIC and he assures me that it has only required sealing so much because the previous occupiers had not sealed it regularly enough.
Last August it was power washed, then coated with xylene before applying a top coat of acrylic sealer mixed with xylene.
This year it was power washed again, then brushed clean on the day of application. I mixed the acrylic sealer with the Xylene and applied it using a soft broom. After the first coat was touch dry I applied the second coat.
It’s quite expensive to seal the drive and the total cost of materials was about £250, so I hope it does not need doing now for a couple of years!
Sealing patterned imprinted concrete drive
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- After power washing and two coats of sealer/xylene
- photo 1 (Medium).JPG (155.67 KiB) Viewed 2571 times
- Before
- S7020177 (Medium).JPG (159.45 KiB) Viewed 2571 times
- Before
- S7020167 (Medium).JPG (117.53 KiB) Viewed 2571 times
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
Re: Sealing patterned imprinted concrete drive
That's quite a nice looking drive, good to see the expansion gaps in.
If they have the sealer when laid, they should look good for quite a few years.
