Something we need to be made aware of?
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
I made my first even veture into 'Subway' last week (and, no, the experience wasn't worth the effort) but whilst in there I was looking at their lighting arrangement.
It consisted of some 32 dual-CFL fittings (round) placed in a square above the interior space. This amounts to 64 lamps of which a TOTAL OF 24 were dud So out of 64 CFL tubes, nearly 40% were defective.
Colour me sceptical but aren't CFLs sooper-dooper long-life as compared to filament bulbs?
So, apart from the expense of having to purchase and install 32 light fittings (as opposed to, say, 9 dual fluorescent strips) and the legally sensitive (?) repalcement/disposal of the dud CFLs - why would anyone in their right mind fit them? Surely in this example the costs can't outweigh the savings????
Green? Like f**k
Green? Like f**k
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
Re: Something we need to be made aware of?
my thoughts would be with that many would they not be on several circuits
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
In their defence, you (or I) don't know how long they have been there. Probability says they are on 12 hours / day at least though.
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
We use a lot of cfl's at work out of nearly 4000 bulbs its got to be 1500 that are cfl a lot depends on where they are fitted and how many times they are turned on and off
We have bulbs that can last a year and others that last 3 months
And they are far from cheap to buy seeing that we can buy 40w candle filament bulbs for 17pence
- kellys_eye
b-a the dud lamps were quite obviously dud - wierd dull glow from them and randomly dud across the whole lot, not 'off', that's for sure.
s-e my own experience of them (in our shop) is that they most certainly don't like being on/off, being far worse for longevity than even filament bulbs, but 12-hour days really shouldn't pose a problem for them should it? Or do the proponents of them mean for them to be on 100% of the time to meet with their supposed 'benefits'?
phil - I was prudent enought to purchase 'loads' of CFLs when the supermarkets were shovelling them out for 9p or 11p each but at the going rate (£2 - £4) I'd baulk at buying even ONE nowadays. I suppose at the industrial quantities the likes of Subway use they will be cheaper but - still - it ain't cheap. never mind the proper disposal techniques that 'should' be employed
- big-all
- Pro Carpenter
weird dull glow induced load ??
i am not for one second doubting what you say but i am just thinking off my bulbs i bought in the 80s still going all be it in a seldom used light
- kellys_eye
No, I definately know the difference b-a Dud.
- Has thanked: 25 times
- Been thanked: 116 times
I've got one of the old jam jar ones still, but it's been in a drawer for a few years now. Still worked when last used, but just took ages to warm up, and wasn't as bright as the modern ones, weighs a ton too :)big-all wrote:weird dull glow induced load ??
I've probably only had 2 CFLs fail in the last 5 years, and one of these was in an outdoor lantern, not sure if that would have made a difference.
I am not a pro.
