Best way to fix cabinets together?
CarpenterChris
Has thanked: 2 times
Been thanked: 2 times
Post by CarpenterChris »
What is the easiest way to screw 2 cabinets together so they don't move? I understand about batten to the wall and fix them that way, but whats the easiest way to screw the front of them together so they don't move?
To try and emphasis what I mean, I have drawn a very crude MS Paint diagram.
(Please note, I am available to do Architectural Drawings! :lol: :oops: )
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: Best way to fix cabinets together?
Post by philprime »
I always clamp the fronts together and screw through both cabinets where the hinges are that way you don't see the screws with hinges are fitted
CarpenterChris
What size screws do you use? I'm just about to do a howdens kitchen for a client and am terrified of screws going through the cabinets haha.
Has thanked: 736 times
Been thanked: 2341 times
just be aware the cabinets must be without any gaps before you screw them together
if you "pull" them together you will distort one or both cabinets
philprime
Post by philprime »
I use either a inch or 30mm screws
joinerjohn
Has thanked: 17 times
Been thanked: 315 times
Post by joinerjohn »
I usually clamp the units together (so they are lined up with each other, then use a Trend Snappy (countersink/pilot hole bit) set to about an inch depth, to pilot and c/sink one side, and use a 25mm screw to fix the units together. As philprime says, I do this where the screw head will be hidden by the hinges, but on base units, I sometimes position the top screw about 1/2" for the top of the unit and an inch back (never seen as it's hidden from normal view by the top of the unit and the w/top) :wink: :wink:
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
What's wrong with using these?
Cabinet fixing bolts.jpg (6.65 KiB) Viewed 3566 times
By eck! ©
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Gadget wrote:What's wrong with using these?
A bit slow really, (and a bit old hat) 30X4mm screw behind the hinges (where possible) for me too.
Gadget
Jack Of All Trades
Post by Gadget »
A bit slow really,.
How do you make that out?........takes seconds once the cabinets are tight together!
By eck! ©
ayjay
Post by ayjay »
Gadget wrote:
A bit slow really,.
OK, let's have a race, ready, steady, GO.......
I've now put my screw in and you've drilled a 5mm hole.
I've finished.
I win. :huray:
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
big-all wrote:just be aware the cabinets must be without any gaps before you screw them together
Normally i'd agree but he said it's a Howdens kitchen so in fact he'd be un-distorting and squaring them back up :lol:
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
As the others. 30mm screw hidden by the hinge. You'll find suitable screws are provided with the units.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Nothing wrong with those. I use them.
I also use the screw method behind the hinge plate.
On the handmade kitchens I used to screw and then pellet, because you can't screw behind a butt hinge. The cabinets would also get screwed and pelleted onto the scribed plinth base.
Return to “Kitchen Fitting”
