Best grout in bathroom
Posted: Fri Oct 25, 2013 6:57 am
by bgatty68
This is to all you pros
out there. Do all white grouts perform the same, the reason i ask is that is there a grout that will stay as white as the day is was first put on or do they all fade in time
if so what is the best grout to use in a bathroom and around a bath with an over head shower
cheers guys in advance
Re: Best grout in bathroom
Posted: Fri Oct 25, 2013 7:05 am
by wine~o
Get one with added "Microban" (bal for instance).
This helps the grout stay white..but doesn't stop discolouration altogether..
Previous home our grout was turning green..eventually worked out it was due to using "shield" soap when showering...which is green.
Posted: Fri Oct 25, 2013 7:24 am
by bgatty68
cheers wine~o, glad someone else is up early to
:thumbright
