Adding a halogen light to a loop-in circuit
Hi
I would like a bit of advice about adding a halogen fitting to an existing loop-in circuit.
I was thinking of adding a junction box in the circuit and running a cable to the halogen light and another to the new switch. I think it'll work but I'd like to know if you think it is safe?
(I've drawn a couple of very basic diagrams to help decipher my description)
The halogen fitting is 5x35w so will 1mm2 twin&earth be sufficient?
In case you ask, the reason I wasn't going to add the halogen as a loop-in is ease of access but if you have any other suggestions for methods I would be pleased to hear them.
- current circuit
- Current circuit.jpg (9.58 KiB) Viewed 2139 times
- Proposed circuit
- Proposed circuit.jpg (12.48 KiB) Viewed 2139 times
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- BANNED
- Been thanked: 2 times
Breaking into loop-in lighting circuits is the reason they make 4-terminal JBs, so it's perfectly OK.
Yes, JBs need to be accessible, but that term is a bit vague - if you can get to it via a downlight hole in the ceiling, or by lifting the floor above, then you'll be no worse off than millions of existing houses.
If there is no access through the ceiling, and the floor above cannot be lifted, then you have a problem.
As for cable, use whatever size the existing lighting circuit is wired in.
Are you aware of the notification requirements if this is in a kitchen/bathroom/shower-room etc?
I'm sorry - I can't come in to work today, the voices are telling me to stay at home and clean the guns.
[size=9][color=white].[/color] [/size]
- BANNED
