Earth circuits
- chrg40is
- Has thanked: 1 time
Earth circuits
Hello none of my ceiling roses have an earth conection in them
Also none of the switches are earthed ither
Does this mean my whole lighting circuits need rewiring
- Deceased 21-10-2011 R.I.P
- Has thanked: 8 times
- Been thanked: 90 times
40 years plus.
But if the cables are in PVC rather than vulcanised indiarubber or lead sheathed, they are almost certainly OK. However, without an earth wire you can't use metal clad switches and lighting fittings must not be metal (other than the lampholder). That rules out a lot of modern lighting.
- chrg40is
some of the light fittings are metal when we moved in
The earth circuits for the sockets seem to be compleatly seperate to the ring main
the ring main is two core wire with a seperate bare/non insulated earth wire which follows the circuit round
all cables are pvc
I have tested the sockets with a simple plugin tester from b and q and all are ok
I cant find any earth bonding any where where do i need to look to find this
all cables are pvc
- davek0974
- Has thanked: 103 times
- Been thanked: 20 times
Look for earth bonding in the bathroom and under the kitchen sink, also near gas meter. You are looking for a heavy green/yellow wire joining the pipes together, i have a feeling you wont find any.
I have never seen wiring with a seperate earth even more odd considering the PVC cable. I guess its no less safe than normal wiring, at least its earthed I would be concerned about the lighting circuits though.
Maybe one of the pro sparks could give an acurate age to this type of wiring.
Dave
Dave
DIY - Joining things together to make stuff ;)
https://davekearley.co.uk/
- Rich-Ando
- Pro Tradesman
- Has thanked: 135 times
- Been thanked: 304 times
and a tester from B&Q will NOT tell you how good or bad the earth is. it will only show a polarity check. (unless you actually bought an EARTH LOOP IMPEDANCE TESTER)
as Stoday stated though, you shouldn't have metal light fitting or switches with no earth.
it makes no difference to me saying it because i won't benefit from it but i would have no hesitation in rewiring it. even sockets of that age tended to have spur off spurs or even all spurs. the fact the lighting has no earth is enough indication to warrant a rewire alone.
the recommended max term is 25 years anyway (although i think that is a bit extreme)
- chrg40is
No the tester was the cheap type with three lights on the back
And yes some of the sockets are spurs of spurs of spurs
As I suspected when I inquired about my consumer unit see previous posts a complete rewire is req
replacement-of-old-consumer-unit-with-m ... t6448.html
Thanks for your help
