Well Placed Drain Cocks - plus Electrics ...
This is where you can post pictures of extremely poor workmanship, whether it is done by a dodgy tradesman or by an incompetent DIY'er. Instructions on how to post pictures can be found in here.
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
Heating
What has really annoyed me is that my CH system has no way of properly draining down the pipework, but when I was moving some pipes today to get rid of some surface-mounted downpipes, I finally found that the installers DID fit one :thumbright:
Here it is...
Pictures removed or deleted by host or original poster
And here is a better view - where you can see it is cleverly located under the floorboards which were nailed down :roll:
It was unusual that this board was nailed down, as just about every other place the boards were lifted to do the heating, they were just dropped back into place and left loose./
Onto Electrics....
Not sure if this a Rogue one or not officially (should be in my book!)
Is it ok when rewiring ground floor sockets to just let the excess cable lay on the dirt underneath?
This is the main ring main - one cable is going off to one socket and is just laying on the dirt , the other cable is coming from another socket and again just dropped on the dirt :shock:
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
seems fine to me!
The drain off should be somewhere more visible! I ususally put one on the rad pipe near a outside door.
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
Either your plumbers re-used some old pipe, or whatever is below the drain off used to be accessible or on show as the pipe is painted white., As for the underfloor cables, some contractors make a decent kob and clip it or suspend it, others just lay it in the dirt as shown
Nick
Hoovie
Borders Bodger
Post by Hoovie »
well spotted :lol: I think he used a load of old pipe - all the pipework under the ground floor is glossed. Pretty shoddy work all in all - the pipes go up and down and cross cross, most have fallen off the clips.
I have fitted a new tee off at the lowest point and fed that to a drain off point outside :thumbright:
Heating was fitted 25 years ago next month in fact - found part of front page of Daily Telegraph with smears of white stuff (prob flux) under one set of pipes :roll:
Hinton Heating
Gas/Heating Expert
just a point, the pipes within a suspended floor should be lagged! :-)
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
I've just re-used some copper pipe I installed about about ten years ago, both carrying heating water so can't be used again for potable water. Some have paint on, but with copper the price it is at the moment, reasonable to re-use. Is it true that when copper prices are high, the quality is down? I ask because I've noticed that it corrodes more readily.
Hinton Heating
Gas/Heating Expert
I reuse quite a bit of copper pipe nowadays... As you say copper is so expensive, and the old stuff cleans up fine! :-)
as you rightly say, any potable water should be done with new pipes.
I'd use a cold main for gas, providing i'm sure its completly dry.
Hoovie
Borders Bodger
Post by Hoovie »
Hinton Heating wrote:just a point, the pipes within a suspended floor should be lagged! :-)
Lagging?!!! these guys never heard of the stuff! I was astounded when I saw not a single bit of lagging under the floor :shock:
I am lagging everything as I go along :thumbright:
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
Hoovie wrote: I am lagging everything as I go along :thumbright:
Well get a move on,your lagging behind schedule :lol:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Hoovie
Borders Bodger
Post by Hoovie »
:lol: :lol:
Everything is lagging now I decided to move and lag the pipes - lost the whole weekend to it :cb
Oh - found another drian off :thumbright: - under the floorboards again, obviously :roll:
owen
Been thanked: 1 time
Post by owen »
Hoovie wrote::lol: :lol:
surely if the lowest point of the system is below the floorboards, then that's where the drain cock needs to be otherwise you would never be able to drain the system properly?
Hoovie
Borders Bodger
Post by Hoovie »
That is very true.
But what I personally would have expected (and what I had in my last house) is a drain cock outside fed from below the boards.
This is in fact what I have now fitted, and due to oddity in the house build, my new drain off is not just below the floorboards, but below most of the ground level :lol:
Hinton Heating
Gas/Heating Expert
quite rare to have external drain offs!
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
Post by village idiot »
mine has an extenal drain off, installed less than a month ago
DONT GET ME STARTED ON THE FVCKWITS FROM SCOTTISH GAS WHO DID THE INSTALL :angryfire:
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Hoovie
Borders Bodger
Post by Hoovie »
tell us more :shock:
Return to “Rogues Gallery”
