Using PVA Bonding
Posted: Mon Nov 18, 2013 11:19 am
by johnM20
Is there any benefit or detriment in using PVA bonding on new plaster board and Aquapanel before I tile onto the boards. I know it is recommended to use on plaster skim coat but not sure about new, unskimmed board.
Re: Using PVA Bonding
Posted: Mon Nov 18, 2013 11:23 am
by wine~o
johnM20 wrote: I know it is recommended to use on plaster skim coat but not sure about new, unskimmed board.
Quite the opposite...
to-use-pva-in-paint-or-not-that-is-the- ... 18116.html
And the same can be said for tiling...
http://www.ultimatehandyman.co.uk/tilin ... se_pva.htm
EDIT..Ooops Mis-read your post, of course it can be used to contol suction when applying a skim coat...for some reason I read "Mist coat"
Still shouldn't be used before tiling though...
Posted: Mon Nov 18, 2013 5:29 pm
by johnM20
Hi Wine~o
Thanks for your reply and the link. The tile adhesive that I have used in the past is Uni-Bond which states on the bucket "Very porous surfaces should be primed using a mixture of 1 part Unibond PVA to 5 parts water which must be allowed to dry". The question is is new plasterboard or Aquapanel classed as a 'very porous surface '?
Johnm20
Posted: Mon Nov 18, 2013 5:35 pm
by wine~o
johnM20 wrote:Hi Wine~o
Ah...Ok so you are using a
ready mixed adhesive..completely different ball game..
what size tiles are you using ?? anything above 250mm sq will be a no-no (IMHO) for a ready mixed addy...
However if you are using ready mixed then
follow the manufacturers instructions.
Posted: Mon Nov 18, 2013 7:38 pm
by johnM20
The tiles are 330 x 250mm to cover a total area of approximately 14 square metres.
I'd thought of using powder adhesive as I've been told it is less expensive but because I may be doing the job over several days I thought ready mixed may be more convenient. I'm very happy to guided by someone who knows better than I do.
Posted: Thu Nov 21, 2013 10:54 pm
by royaloakcarpentry
The tiles are too big for ready mixed adhesive, they need to be on a cement based addy.
No excuses for ready mixed being used in a bathroom, anyway.
Unibond is shat adhesive for starters.
Posted: Mon Nov 25, 2013 10:24 am
by haveagohero
Unibond is pants! the fact that they still recommend PVA as a primer says it all really. As said use a cement based adhesive. Buy slow set and you can mix up a big batch at a time. Plasterboard doesn't need primed but I can't comment on aquapanel as I don't use it but I imagine it is also fine without priming
