Maplins angle grinder and blade £9.99 both.
Bludall
Forum Chatterbox
Has thanked: 39 times
Been thanked: 7 times
Post by Bludall »
Offered in Maplins now
600W Angle Grinder & free Blade Offer
Angle Grinder
• 115mm disc diameter
• No load speed: 11000rpm
• Weight: 1.7kg
Diamond Blade
• 115mm diameter segmented dry cutting blade
• Ideal for cutting concrete, stone, bricks etc
• Ideal for use with most 115mm angle grinders
£9.99 for both, would it be worth having in my tool kit?
Failure means you just didn't get it right yet!
Louise
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
£9.99 - sounds too good a bargain to be true :shock: - or to miss :lol:
May as well buy two of them :thumbright:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
It's cheap enough, but cheap does not mean good.
Cheap angle grinders normally cause more vibration during use, but it would be very handy at that price especially as it has a diamond blade with it. For occassional use it will be fine :thumbright:
Bludall
Forum Chatterbox
Post by Bludall »
Birthday pressie I think!
A link http://www.maplin.co.uk/Module.aspx?Mod ... T=12356483
Sorry I couldn't get it to shorten, no idea why!
Louise
I like diamond disks.
Even the cheap ones are much safer then abrasive disks.
Abrasive disks can be dangerous as it is not unusual for them to disintegrate and at 15,000 rpm's they can easily cause bad injuries.
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
That appears a good buy if you only use it occasionally especially as Chez says with the diamond disc. I have a Hilka "Pro" that has been given quite a lot of grief over several years and it still works :thumbright:
Peter C
The end justifies the means
Bludall
Forum Chatterbox
Post by Bludall »
I wondered if it would be able to cope with cutting concrete fence plinths in half.
Louise
peter c
Post by peter c »
Doubt it. I would use a 9 inch angle grinder but be careful as often concrete posts etc have metal re-inforcing bars that could mess up the blade.
Peter C
Bludall
Forum Chatterbox
Post by Bludall »
I used a chisel last time and cut two in half by hand, then I got my trusty hacksaw and cut the metal. It took ages.
Louise
peter c
Post by peter c »
Can believe that. Obviously you are not a lady to be messed with if you can wield a club hammer :lol: :lol:
Peter C
Bludall
Forum Chatterbox
Post by Bludall »
It must be my upbringing. I was my dad's helper from an early age on many of his house renovation projects and as long as I know what to do I'll have a go. I just need to be 100% sure that what I'm doing is right.
Proof, aged about 9/10 helping with the house build! :lol:
Louise
peter c
Post by peter c »
I believe you honest :thumbright: :lol:
Peter C
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
That looks like a picture from a kids story book :lol:
If your only using it for 5mins every other month, its worth £10.
For regular high use, like myself, it wouldnt last 30 seconds, and the vibrations would be phenomenal :roll:
It will cut your concrete, but not as quick as a 9"
Still quicker than a chisel and hacksaw though :lol:
Bludall
Forum Chatterbox
Post by Bludall »
peter c wrote:I believe you honest :thumbright: :lol:
I think my dad took the pic because my brother and I were arguing at the time and I was holding the dangerous tool! It was around 73/74!
Hitch wrote:If your only using it for 5mins every other month, its worth £10.
I thought I'd better ask the oh if he'd use one to be on the safe side! He's not too keen and said he'd rather have a 3 in 1 jacket. that's a first, clothing over tools! :lol:
Louise
Return to “Tool Talk”
