I'm looking to take out an existing base unit (with no wall unit above it) and replace it with a larder unit for an integrated fridge freezer. The unit is up against a wall, so I would have the door opening restricted to 90 degrees, minus a few degrees as the handle will hit the wall if fully opened.
Does anybody know if that would cause any issues? I'm thinking I might need a spacer between the wall and the new unit of a few centimetres to ensure it can open the full 90 degrees or maybe a bit more. If I have to add a spacer it throws the measurements out as this is a modification my kitchen rather than me starting from scratch and being able to factor it in easily.
Will doing it without a spacer cause any issues?
![thumbleft :thumbleft:](./images/smilies/icon_thumright.gif)
