Kitchen cabinet doors
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
I have just bought some oak kitchen doors and I need to cut out the 35mm hinge holes. I have bought a SFZ hinge cutter 11596. Is it better to use the cutter in a drill stand or in my half inch router?
Sorry I don't seem to be able to add the link to the SFX page ::b
Peter C
The end justifies the means
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
Hi Peter, i would use the drill stand mate. :thumbright:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Has thanked: 823 times
Been thanked: 3560 times
I have done loads free hand. Punch a dink to catch the cutter point on centre. Once started the cutting efficiency can be increased by tilting a very small degree and then pulling up straight, The cutter depth is about equal to the countersink required for the hinges so stop when it is flush with teh surface. With a drill stand you lose the 'feel' and bite. In hard woods the cutter can polish the cutting surface and skid which is why the slight tilt helps
Try a drill stand and do a free hand cuts on scrap and see what suits.
Tryanything
Been thanked: 4 times
Post by Tryanything »
Pillar drill would be my prefered method but using a router will do the same job, use the router fence and depth stop to make the job easier
There would be less trouble in the world
if l had not had six daughters
peter c
Post by peter c »
Thanks guys. On MDF doors I have cut the holes both free hand and with the drill stand but with oak doors just wanted to see what your advice was.
Peter C
