what to tool do i need to make a bigger channel in stainless
irfs
Post by irfs »
Hi guys im needing some expert advise here, I have a stainless steel deck there are 4 channels on this deck I need to make them deeper and wider. if I get a dremmel or drill is there a drill bit which I can use that can sand stainless steel. need to go half mm either side and half mm deeper. Someone pls advise
I need it to look like the pic, my channels are not as deep and not so wide on all 4 channels.
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Re: what to tool do i need to make a bigger channel in stain
Post by wine~o »
:welcomeuhm:
Not a clue, stainless steel is seriously hard for cutting, might do better/be less expensive to buy the proper kit in the first place..
TWR1
Has thanked: 4 times
Post by TWR1 »
What you need is a milling machine!!
Find a local engineering company, they could do it no probs
