Hardboarding prior to laying lino.
hiking bear
Post by hiking bear »
Im putting down some new lino in my kitchen. Previously it was hardboarded, but not very well! The joins showed through the lino after a couple of years and i dont want that happening again. I intend to lay new hardboard, 3.5mm.Should the joints be sealed with a mastic or possibly taped? Any advice welcomed...
ali
Post by ali »
Actually I'd be interested in the answer to this too.
We got a new chipboard floor laid in our kitchen but it's pretty rough and the nail gun the joiner used has sunk the nails with such force that they're almost out the other side! There are also joins that are a bit nasty.
We're still toying whether to go with tiles or lino. I like the look of tiles but my gut feeling is that lino would be more practical with my lot and the newbie very dirty, mud loving, lab pup we have aquired.
But we'd need to put down sheets as in the post above if we laid lino, so please advise hiking bear so I can copy him! :wink: :lol:
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
I'm no expert on floor coverings, but if you lay the hardboard so that the manufactured edges are butted together (rather than manually cut edges) and you are using good quality lino, ....the joins shouldn't show through!
By eck! ©
skiking
Been thanked: 4 times
Post by skiking »
I've not done this type of flooring in about 15 years - and then only the once - but when I laid hardboard I wet it all first altho' I can't remember whether I let it dry out first (I assume I did) but it was left in the room it was to be fitted in for a couple of days prior to fitting.
One of the pro's will confirm whether this is right or not :roll:
Gadget
Jack Of All Trades
Post by Gadget »
skiking wrote:I've not done this type of flooring in about 15 years - and then only the once - but when I laid hardboard I wet it all first altho' I can't remember whether I let it dry out first (I assume I did) but it was left in the room it was to be fitted in for a couple of days prior to fitting.
Spot on Skiks, I'd forgotten about that!!.........You should get the hardboard wet, and lay it when it's still wet!!...........When it dries, it will be as tight as a drum!!
By eck! ©
davek0974
Has thanked: 104 times
Been thanked: 20 times
Post by davek0974 »
I was told to always soak the rough underside of the hardboard before laying, leave it half hour then lay it before it dries out fully to stop bubbling etc.
Worked for me.
DIY - Joining things together to make stuff ;)
https://davekearley.co.uk/
Jenny the novice
Has thanked: 19 times
Post by Jenny the novice »
ali wrote: We're still toying whether to go with tiles or lino. I like the look of tiles but my gut feeling is that lino would be more practical with my lot and the newbie very dirty, mud loving, lab pup we have aquired.
My sisters puppy destroyed most of her lino by trying to dig under the door :lol:
