Tiling Around Sockets
leew
Has thanked: 23 times
Been thanked: 1 time
Post by leew »
Alrite guys.
Anyone tell me how I make this look good? Thinking take sockets off then try to squeeze a cut tile in but bit concerned about the edges being too thin to do this.
I thought about grouting it but it would look $h!te I thought with a massive grout line between socket and tile.
Any advice please?
Cheers.
leew
Re: Tiling Around Sockets
Post by leew »
Looking to plod on tomorrow so get them suggestions in please if you don't mind!
First time tiling so need all the help I can get!!
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
You need a tile nibbler or a tile saw - you'll likely break a couple getting one right (well, I would) , but it will be better than huge grout lines.
blackvenom
Has thanked: 8 times
Been thanked: 8 times
Post by blackvenom »
You'll notice there is a difference in width from the metal box to the socket plate. When I did my kitchen I unscrewed all the sockets from the boxes and tiled very nearly up to the edge of the metal box then when you screw your plate back on you'll have a nice finish
Oh and I have this tile cutter that I've used for a bathroom, kitchen and two small floors and it's served me well. If I had to buy one again though I would go for a more powerful one but this one is still a trooper.
http://m.wickes.co.uk/450W-Tile-Cutting-Saw/p/215754
Sent from my iPhone 5 using Tapatalk
Chris Skilbeck
Has thanked: 132 times
Been thanked: 238 times
Post by Chris Skilbeck »
Yes, what he said - and I've successfully cut thin pieces of tile with a diamond edged disc on a small angle grinder (in fact it's what I use for all tile cutting). Go steady and don't bring the disc off at an edge - cut into the edge-glaze from both ends of the cut. For fine pieces, or shaped pieces, I tend to hold the tile in one hand and the grinder in the other, but this is probably a bit dangerous if you haven't got big hands and a firm grip, so hold the tile down firmly on a clean piece of flat wood - clean it between cuts, too, or you'll end up cracking tiles.
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Post by Timllfixit »
Dremmels are great for this sort of thing.
Has thanked: 820 times
Been thanked: 3519 times
I did the same tile and pattern job and met the same problem around the sockets. I think it is worth £30 buying a power tile saw like this http://www.screwfix.com/p/energer-enb52 ... 240v/61123 You really can cut thin strips and shape tiles quite easily. I cut a u-shape in a tile to slide in under the socket. By cutting a number of parallel lines and then carefully snapping the waste ones off to a scored line made with a tile cutter.
I have done loads of work with my £30 tile cutter and it is still going strong.
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Post by wine~o »
+1 for DWD's advice.. even a cheap wet cutter is great for some of the more fiddly cuts.
Good idea to get a tile file as well to remove any sharp edges...electric wires/cables and sharp edges don't mix..
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
And you can get longer socket face plate screws from Maplin.
ILikeDIY
Been thanked: 2 times
Post by ILikeDIY »
The socket looks to be on crooked:
If you straighten it out it would make cutting the tile much easier, as you won't have to make it so thin in certain areas.
Use a wet saw tile cutter like this:
http://www.amazon.co.uk/VITREX-103402-D ... B000C74Y6M
I got mine from Wilkinson's for around £34. Makes profile cuts so east, even do curves on it.
To get the U-shape you make a succession of cuts along the red lines:
Then snap them off at the blue line (snap them sideways), and file it smooth a little. You will be left with the black outline.
Return to “Tiling Forum”
