Knock of and Render Job
cotswold builders
Has thanked: 216 times
Been thanked: 1070 times
Post by cotswold builders »
Rained a bit this morning so knocked of damp internal plaster above window head.
Quite a thickness to bond out, applied in 3 coats.
Bonding done Monday afternoon.
Normally you would bond and skim in the same day but the bonding wouldn't go of quick enough, couple of options, pva and skim, or as I did spray with water, ( goes of quicker )
All the render of gable wall, 2 of us in a day and cleared away.
Pick up 1.5 ton plastering sand, ( loads cheaper than bulk bags )
These are the chisels we use for knocking of ( scutch chisels ) by the time you have unwound the extension cable and got the breakers out you can knock of a couple of metres.
Hopefully, sbr, scratch coat Wednesday, float coat Thursday.
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Re: Knock of and Render Job
Post by wine~o »
:huray: :huray: Cotswold has mastered adding pics and text...
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Post by Wes »
Congratulations on popping your picture cherry CB :thumbright:
cotswold builders
wine~o wrote::huray: :huray: Cotswold has mastered adding pics and text...
Ha, but it took me longer to resize the pictures than it did to knock the render of. :-)
I resized them to 500 pixels. is that right, or can I make them bigger ?
wine~o
Post by wine~o »
500 is fine..1200 is the max for this site...
Wes
Post by Wes »
Download the picture resize software and it'll be done in a jiffy :-)
Have you watched the 'how to resize picture' video Chez did??
cotswold builders
Wes wrote:Download the picture resize software and it'll be done in a jiffy :-)
no, where is it ?
Hardip
Has thanked: 4 times
Been thanked: 2 times
Post by Hardip »
lagi
Has thanked: 141 times
Been thanked: 53 times
Post by lagi »
Nice tip about the scutch chisels, didn't know that.
paul the spread
Has thanked: 5 times
Been thanked: 23 times
Post by paul the spread »
cotswold builders wrote:Hopefully, sbr, scratch coat Wednesday, float coat Thursday.
be better if you could give it a day or twos rest in between scratch and top
and i prefer hand chisels too mate
cotswold builders
Hi Paul, yes leaving till Friday for float coat.
cotswold builders
Application of sbr, mixed nearly neat, just enough water to run through the sprayer.
Starting the scratch coat and setting beads.
Scratch coat completed, will leave it until Friday for the float coat.
Scratch coat mix, 4 sand to 1 cement, febmix plus water proofer.
Top coat will be 5 to 1 with only febmix added, if the top coat was left to long then water proofer would be added to give you more working time.
If its to dry Friday, just dampen with water.
cotswold builders
lagi wrote:Nice tip about the scutch chisels, didn't know that.
You can also get them in hammer form ( brick hammer ) and different sized chisels, the combs are only a few pence, and also come in flat blade, to change the blade knock them out with a hammer.
cotswold builders
Hardip wrote:Here
Thanks for the link, I down loaded it but couldn't find where to change the pixels.
wine~o
Post by wine~o »
Feck me Cotswold...you are gonna fall off that scaffold...
cotswols is gonna fall off........JPG (334.11 KiB) Viewed 5157 times
Phew....I've saved you.. :huray:
Return to “Show Case Gallery”
