Wera Hex-Plus Multi-Coloured BlackLaser Hex Key Set
- Has thanked: 2 times
- Been thanked: 19 times
Here is my review of the Wera Hex-Plus Multi-Coloured BlackLaser Hex Key Set, officially named "950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser" on the Wera site.
These come in an all-green sleeved set, or the multi-coloured set pictured. The sleeving is plastic, and provides a solid grip - It's well stuck on, durable, and doesn't slide about. I went for the multi-coloured set as they were slightly cheaper, but the colours can help to distinguish between the different sizes. The holder easily locks and unlocks by sliding the green latch on the side, and the keys hold in their slots very well, but are also removed without much trouble.
Something great about these is that compared to a standard set of hex keys, they are much larger, allowing you to apply a greater torque. The largest 10mm key is almost 24cm in length.
The best thing about these is definitely the ball on the end, allowing you to use the keys at an angle. It works really well, I don't have any difficulty using them at angles. The Hex-Plus profile also allows up to 20% more torque to be applied, according to Wera, and reduces the chance of rounding off the fastener. I think they also help a bit with getting out lightly rounded fasteners, so you can try these before hammering in a torx bit.
I think it's safe to say these are the best hex keys in existence. The hex-plus profile, large size, and brilliant ball on the end makes these effective and very easy to use. They go for around £20.
Highly recommended!
- These users thanked the author Liam2349 for the post (total 5):
- transitboy • ultimatehandyman • Dave54 • steviejoiner74 • Dickie
- Rating: 35.71%
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Re: Wera Hex-Plus Multi-Coloured BlackLaser Hex Key Set
I have the same set except that mine is the plain green variety - because I couldn't see any advantage in colour coding the sizes (I'd never remember the colours in any case). Good selection of sizes 1.5 - 2 - 2.5 - 3 - 4 - 5 - 6 - 8- 10mm) which will cover everyday use for most people. The holder on mibe has a small magnetic metal piece which is very handy for keeping small grub screws and the like from wandering off. In my tool kit I also have the equivalent Wera Torx key set which has an identical holder and comes with sizes TX8, TX9, TX10, TX15, TX20, TX25, TX27, TX30 and TX40. Sizes TX15 to TX40 come with ball ends on the long "arms" which are extremely handy for getting at hard to reach fasteners. Both were a tad pricey, but have been excellent tools
Haven't noticed any magnet on my set, so that's interesting. I've seen the Torx set and that also looks nice.Job and Knock wrote:I have the same set except that mine is the plain green variety - because I couldn't see any advantage in colour coding the sizes (I'd never remember the colours in any case). Good selection of sizes 1.5 - 2 - 2.5 - 3 - 4 - 5 - 6 - 8- 10mm) which will cover everyday use for most people. The holder on mibe has a small magnetic metal piece which is very handy for keeping small grub screws and the like from wandering off. In my tool kit I also have the equivalent Wera Torx key set which has an identical holder and comes with sizes TX8, TX9, TX10, TX15, TX20, TX25, TX27, TX30 and TX40. Sizes TX15 to TX40 come with ball ends on the long "arms" which are extremely handy for getting at hard to reach fasteners. Both were a tad pricey, but have been excellent tools
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
That's an awesome set of Hex Keys and great review
- Has thanked: 1300 times
- Been thanked: 1175 times
Thanks for the review. Nice set of keys.
Only thing I would say is that with them being longer than normal, be a bit careful not to overtighten with the smaller sizes.
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Great review,how much is a set?
My mistake,I see you've already said they are 20 quid,good value!
I've got the same set of keys and I'm also very pleased with them, they've managed to get some nearly stripped out hex bolts out, where my others just slipped.
The magnetic holder is more than that: it has a + and a - side, meant to magnetize/demagnetize your L-keys. Very useful and clever! Just lay the wrench on the plus side to magnetize it for difficult to reach screws; then when you're done (I usually dislike magnetized tools), you run it through the minus slot, that also locks in the flappy bit.
- DSC000792.jpg (286.15 KiB) Viewed 11460 times
