Upstands - cutting
Grommit
Has thanked: 1 time
Upstands - cutting
Post by Grommit »
What's the best way to cut worktop up stands? They are 120mm tall so won't fit in my mitre saw (only single bevel). Should I hire a double bevel saw or is it possible to cut them using a clamping mitre box. There are 2 external mitres and 2 internals so don't want it to look naff.
If I were to hire one from HSS do they come with a good enough blade or would I need to get a better blade in advance?
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: Upstands - cutting
Post by philprime »
You can get mitres on a single bevel mitre saw
Grommit
Has thanked: 1 time
Post by Grommit »
How? It chips the top if it is facing towards the back of the saw and turning it the over way up so the front is facing upwards results in major front chippage.
Am I missing something or do i just need a better mitre saw?
philprime
Post by philprime »
How many teeth have you got on your blade?
To cut laminate you need a decent blade I have a 80 tooth to cut upstands
Grommit
Has thanked: 1 time
Post by Grommit »
68 teeth on a 215mm diameter blade. It cuts fine so long as the face is down and the top is pointing away from the back of the saw.
philprime
Post by philprime »
Try covering the cut line with masking tape to reduce break out
Grommit
Has thanked: 1 time
Post by Grommit »
Thanks I shall give that a try.
Here's the results of an earlier test.
Chipping!
Chipping!
2014-04-22 21.16.52.jpg (470.79 KiB) Viewed 9504 times
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
You need a good quality blade,I cut some high gloss upstand today with no problems and no chipping. I have a 60tooth trend blade on my saw at the moment.
philprime
Post by philprime »
Looks like your blade is a bit dull
Laminate it's a killer on blades I have cut worktop to lenght with my circular saw using a 30tooth blade without breakout on laminate covering the cut line with masking tape
Return to “Kitchen Fitting”
