Work photos....
182michael
Has thanked: 28 times
Been thanked: 69 times
Work photos....
Post by 182michael »
Jumping on the bandwagon thanks to Stevies tip about resizing photos. Nothing interesting on my new phone will try to get some off my 4s.
Just started the barn conversion this week will update as work progresses.
Cheers
Traditional build floor
Porch
Porch
Loading up ff panels
Trusses up
Trusses up
Valley detail
Valley detail
Timber kit complete
Timber kit complete
Fascia on
Fascia on
Traditional build roof
2 new builds from last year
Shell
Shell
Loaded up and sole plate down
External panels made up and building paper fitted to cold side
Insulation in
Insulation in
Internal layout set out
Insulation in and subfloor down
These users thanked the author 182michael for the post (total 2):
big-allsteviejoiner74
Rating: 14.29%
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Work photos....
Post by steviejoiner74 »
Cheers for sharing! You've surely mastered the resizing better than me as the photos are nice and clear :thumbright:
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Work photos....
Post by ayjay »
steviejoiner74 wrote: You've surely mastered the resizing better than me as the photos are nice and clear :thumbright:
Resizing to a smaller pic is only likely to make them sharper, you need to hold the camera steady first though. :mrgreen:
182michael
Re: Work photos....
:lol: Aye I used one of the free apps on your link. Easy!
steviejoiner74
Re: Work photos....
By reducing the pixels by over half does that not make the image worse?? :dunno:
ayjay
Re: Work photos....
Post by ayjay »
Not as far as I know.
Blow a picture up to twice the size and it will almost certainly look worse - you can get away with blowing up a picture if it's really sharp to start with but there is still a limit: reducing a pic won't make it less sharp.
It might be dependant on the software used, I only use freebie programmes available on the net, I have no experience or knowledge of phone cameras at all.
steviejoiner74
Re: Work photos....
It said the pic was 3600 x 2600 pixels(roughly) so I reduced it by quite a bit to fit here. I know what you mean by making it bigger it should be of less quality but I'm getting confused now as I've reduced the pixel count which should make it smaller but of less quality as well?? Would cropping the photos be better?
moderator6
UHM Super Moderator
Has thanked: 141 times
Been thanked: 362 times
Re: Work photos....
Post by moderator6 »
steviejoiner74 wrote:It said the pic was 3600 x 2600 pixels(roughly) so I reduced it by quite a bit to fit here. I know what you mean by making it bigger it should be of less quality but I'm getting confused now as I've reduced the pixel count which should make it smaller but of less quality as well?? Would cropping the photos be better?
Reducing the pixel count is fine if you're making the picture smaller :wink:
steviejoiner74
Re: Work photos....
Basically I'm rubbish at taking photos then :lol: :lol:
Has thanked: 736 times
Been thanked: 2341 times
Re: Work photos....
very interesting nice job thanks for sharing them :thumbright:
182michael
Return to “Show Case Gallery”
