Timber frame construction on site
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
For anyone thats interested,how the majority of houses are done up here,this one is 370m2 built on site
image4 (Small).jpg (55.64 KiB) Viewed 5413 times
image3 (Small).jpg (64.44 KiB) Viewed 5413 times
image1 (Small).jpg (55.45 KiB) Viewed 5413 times
image (Small).jpg (61.17 KiB) Viewed 5413 times
These users thanked the author steviejoiner74 for the post:
getthewheelsinline
Has thanked: 734 times
Been thanked: 2335 times
Re: Timber frame construction on site
cracking job
look forward to the follow up pictures :huray: :thumbright:
steviejoiner74
getthewheelsinline
Has thanked: 224 times
Been thanked: 182 times
Post by getthewheelsinline »
Nice build. Who supplies your rafters?
These users thanked the author getthewheelsinline for the post:
steviejoiner74
BRUNO
Has thanked: 34 times
Been thanked: 67 times
Post by BRUNO »
keep them coming steve, brilliant work.
must be hard to raise those walls when youre walking around on joists instead of ply/osb, do you lay that after the walls are up?
cheers
bruno
These users thanked the author BRUNO for the post:
steviejoiner74
steviejoiner74
The trusses were supplied by donalsons of buckhaven,200kg each to manhandle. The flooring goes down after the building is watertight,we just walk over the joists and try not to fall :lol:
This house we built on site as we do with nearly all the jobs,much cheaper than have a timber frame manufacturer supply the kit.
getthewheelsinline
182michael
Has thanked: 28 times
Been thanked: 69 times
Post by 182michael »
Need another 2 joiners? Haha! Cracking looking job stevie. No danger you would catch me hand balling those lol! £400 crane for a day job done
BRUNO
Post by BRUNO »
I laboured to some carpenters in the states for a summer many moons ago. over there they sheathed the floor after the joists went in, framed the walls on the floor the raised them, plumbed and straightened , osb, then next floor then ceiling and rafters. air guns going everywhere, was a real buzz.
thats all untreated timber- is there a reason for that? and the glulam beams, did you make those yourselves or get them in?
cheers
182michael
The way he's done it there looks like how the yanks do it (stick built)
JJI's are probably from donaldsons or national hickman
steviejoiner74
The timber is all treated c16 or c24,glue lams and jji's from donaldsons. This was stick built,you can do it with a 4.8 top and bottom runner so less panel joins and it saves a bit on 6x2.The paper can get done in one go as well so basicaly no waste and eliminates a join at every panel.
182michael
I'm going to try this next time. Surprised you never had to use tf200 foil on the outside fife council bco asked for it on the last 2 I've built.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Have you got to put a top section on those Attic trusses?
That's a poxy job to do, I've only ever done one and I don't want to do another, ( don't like trussed roofs anyway).
182michael
:lol: top hats are murder that's what the apprentice is for :thumbright:
steviejoiner74
This kit comes under Perth and Kinross,it's got 145 kingspan inside and the windows hiked up the u value so it apparently didn't need the foil on the outside.
Those attic truss top hats were horrendous to do,every bloody hole was twist nailed by hand. 4000 nails in all.
400 m2 of sarking on the roof as well.
We have knocked up a few extension recently that have gone back to 4x2 kits for some reason??
182michael
4x2 with a 100mm cavity with 50mm wool in it. Current regs now I believe every new build has changed to that. Firestops then a firebag stapled to it.
I've got a paslode twist nailer but if the apprentices are available then saves on nails :lol:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
That is some house :thumbright:
I bet your nail gun gets some use!
These users thanked the author ultimatehandyman for the post:
steviejoiner74
Return to “Show Case Gallery”
