Does anybody know where I can find a diagram on how to wire a PIR sensor to the main floodlight in my house.i have looked at most places.
Your help would be much appreciated.
Outside Security Light
- Rich-Ando
- Pro Tradesman
- Has thanked: 135 times
- Been thanked: 304 times
look carefully in the pir. if the connections are not written on a sticky label by the connector blocks, try looking hard at the plastic to make sure it isn't moulded on it. failing that check the actual terminal blocks as they sometimes write it on the side of them.
if that doesn't help, take a picture of the insides and we can try from that.
