fixing into steel ?
Reviews of hand tools in this forum please.
BRUNO
Has thanked: 34 times
Been thanked: 67 times
fixing into steel ?
Post by BRUNO »
I want to attach cement board (hardibacker) to steel angle iron 10mm thick.
I was going to use a wonder glue , sticks like , then mechanicaly fix using self tapping screws. but I;d like to get it done before the end of the year..and i forsee a lot of pain trying to drill into 10mm of steel.. :sad:
is there a gun that fires nails into steel, a bit like the hilti guns that fire into concrete??
cheers
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: fixing into steel ?
Post by steviejoiner74 »
Hilti guns fire into steel as well. I've got an old dx450 hilti that shoots into steel no problem.
The problem you might have with using a hilti gun is the cement board will break up,I'd use decent self tapping screws and a tek gun and you'll fix the boards back no problem.
BRUNO
Post by BRUNO »
cheers steve. was thinking the same with the board splitting, thought maybe I could aim the gun at a pre drilled hole.
I dont have a tek gun, or a lot of experience with self tappers and steel. will an impact driver do the same job?
presume i need to pre drill the steel?
any recommendation for screws ?
Liam2349
Has thanked: 2 times
Been thanked: 19 times
Post by Liam2349 »
Not heard of screws that can tap steel before, but concrete self-tappers exist so I guess steel tapping screws must too...
I'd be careful tapping a hole with an impact driver though, could possibly make a mess. My gut instinct tells me to go for a powerful drill or tap wrench instead, for a steadier application of torque, since impact drivers put out huge amounts of torque in a split second.
Also yeah, I think you would have to drill the steel before using self-tapping steel screws.
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
http://m.screwfix.com/p/timco-phillips- ... -200/62277
I have used these in the past I agree with Liam about using an impact driver you will probably be better using a combi drill
BRUNO
Post by BRUNO »
thanks lads , noted about the impact driver
cant get my head around been able to drill 12mil steel with a bit and sink a screw into it, I just never get to work with with steel.
this is the same stuff used in RSJ's and the like, a big lump of 200x100 :scratch:
Return to “Hand tool reviews”
