Stair Spindles - Thank you
- Has thanked: 6 times
- Been thanked: 8 times
chaps, I've completed the landing spindles I was asking advise about a while back and was going to post a pic (how do i do that?) to say thanks and get your critique.
Can anyone tell me ? - my file pixels are too big, must need a resize..
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Stair Spindles - Thank you
I had the same problem for ages,I use an app called image resizer and I can now post photos.
The link to it is on a thread I posted in showcase gallery about stair spindles of all things!
oak-staircase-t73195.html
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
If you are on a fairly modern version of windoze, right click on the image, select "open with" then "Paint"....Dazzer wrote:
Somewhere near top left will be an option to *resize* click on that then *Pixels*
then you will have 2 boxes one will have a higher value than the other..in the one with the higher value enter *1200* the maximum this forum will allow (The other box should change automatically)..
save ......
Of course all of the above assumes you are using a personal computer...
Edit.....because I'm a bit like that...If I want to take a photo, I'll use a camera..If I want to make a phone call or send a text, I'll use my mob phone...If I want to make a post on a forum..I'll use my laptop....
And If I want to read a book I'll buy it when comes out in paperback..(No kindle ..no downloading the f.ing thing......)
- wine~o
loads better.........are you going to paint them ??
- Has thanked: 37 times
- Been thanked: 3 times
- Wes
- Wood Flooring Installer
- Has thanked: 379 times
- Been thanked: 565 times
Far better than before...Although, I'm not sure the base rail works slung under the original banister rail. Looks a little odd. There's your critique
thanks Wes, got a couple of bits to finish (should of said that) - where the base rail is wider at the bottom than the handrail I'm going to piece in some 6mm quadrant (I've allowed for it when setting out) and it'll all be painted white in the end - will post the final pics.
