- It is currently Mon Mar 10, 2025 5:29 am
Metal Handrail
- Been thanked: 2 times
Metal Handrail
Post by stephen ingham »
Hi guys, this is a recent project of mine.
Customer originally had a wooden hand rail which had rotted and broken, so they asked me to replace it with a steel box section one with matching bottom rail.
Hope you all like it?
- after powder coating
- hand rail coated.jpg (252.55 KiB) Viewed 4471 times
- hand rail uncoated.jpg (235.84 KiB) Viewed 4476 times
stephen ingham
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Re: Metal Handrail
Looks good. Are there end caps to be fitted? Why did you go that way rather than welding plates on?
Razor
Re: Metal Handrail
Hi, thanks for the reply.
Yes there are end caps to be fitted, customer insisted rather than welding ends up...
- These users thanked the author stephen ingham for the post:
- Razor
stephen ingham
- Has thanked: 77 times
- Been thanked: 335 times
Re: Metal Handrail
Looks a tidy bit of fab, but it doesn't exactly meet the regs by the look of it.
Was it galved as well as powder? I can't see any vent holes...
Hitch
Re: Metal Handrail
Regs.....what regs are we talking about?
Have i done something wrong?
It was shot blasted, primed and powder coated
stephen ingham
- wine~o
- Has thanked: 1415 times
- Been thanked: 4030 times
Re: Metal Handrail
stephen ingham wrote:Regs.....what regs are we talking about?
100mm between the "Spindles" for a start...
wine~o
Re: Metal Handrail
you are right.....there is 25mm between the 50mm and 25mm ones and 150mm between the 25mm and the 50mm, if that makes sense?
stephen ingham
Re: Metal Handrail
stephen ingham wrote:you are right.....there is 25mm between the 50mm and 25mm ones and 150mm between the 25mm and the 50mm, if that makes sense?
Yeah, I understand what you mean. If thats the case, the height looks pretty low too, it should be 900-1000mm to the top from the pitch line.
Are you in the UK Stephen? If you are, the rails ought to meet building regs, part K.
http://www.planningportal.gov.uk/buildi ... d#Download
Is fabricating this sort of thing your main line of work?
Hitch
Re: Metal Handrail
The height is 925mm from the step to the top of the hand rail....
Yes i am based in West Yorkshire.
No this is not my main line of work, if anything its more of a one off job....
You have me worried now.....should i try and do something about it?
stephen ingham
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2603 times
Re: Metal Handrail
I think its to do with a childs head being able to go through the gap.
Could you not add something (decorative) to reduce the gap, or you could...........
Re: Metal Handrail
For a domestic/public building the guarding shouldn't allow a 100mm sphere to pass through it at any point. Where practical, that would include the gap between the base rail and steps, but that doesn't seem to be enforced unless you get a real nitpicking idiot checking it. But its best to do it properly to avoid any rework in the future.
For public buildings, schools etc, part M also comes into play a lot now.
Below is an example of a rail that is compliant with reg part K & M. so you can see what I mean.
Industrial premises are a bit different, as children wouldn't be deemed as being a user of the building.
Like I say Stephen, it looks a tidy job, seen worse from so called professionals
As of July this year, there is new law coming in that is changing the fabrication industry somewhat, EN1090. Its basically CE marking, ensuring that fabricated structural components are made properly.
- uhmexample.jpg (355.3 KiB) Viewed 4277 times
Hitch
