Is this a pin or a rivet
Mr Red
Has thanked: 50 times
Post by Mr Red »
Hi all,
The 'thing' which holds my ratcheted garden cutters together has failed and I'd like to repair.
Does anyone know what the 'thing' is shown in my picture next to the cutters?
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Re: Is this a pin or a rivet
Post by wine~o »
Looks to be a little rivet....
Chances are it'll cost more in time and effort finding a replacement than replacing the shears....
Mr Red
Post by Mr Red »
wine~o wrote:Looks to be a little rivet....
What kind of rivet would it be? I thought pop at first but aren't they used to fix two items together. This pin would be loose once repaired.
wrinx
Has thanked: 63 times
Been thanked: 59 times
Post by wrinx »
Would a nut and bolt suffice?
wrinx
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Post by Timllfixit »
Perhaps, but it's the principle of the thing. Surely mending stuff is what being a "handyman" is all about?
Quite probably. If that rivet thing is hollow you could file the head off and use the remaining tube to protect the thread of your screw, and give the mechanism something of the correct size to work with. A little nylock nut and a couple of washers and off you go! If you are feeling really adventurous, there is always a cut down nail and a small ball pein hammer.
Mr Red
Post by Mr Red »
wrinx wrote:Would a nut and bolt suffice?
wrinx
Unfortunately not. There is no room for a nut once the handles are closed and the mechanism retreats within the handle.
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
You might get away with a 'roll pin' or a pop rivet by knocking the steel mandrel out and then roll the plain end of the tube after it is inserted into the cutter tool using a centre punch or similar, if you do not have a flaring tool But all a bit hit and miss & trial and error.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I'd either put it back in and beat the end over until it holds (hammer and suitable sized punch) or just buy a new pair of secateurs.
Is the ratchet particularly effective?
I use a reasonable quality pair of anvil secateurs and they work fine, if I need more leverage for cutting thicker stuff a good pruning saw is effective (with backward facing teeth they cut on the pull stroke) - or a pair of loppers.
Pruning saw.
