Plumbing and Kitchen Units
jaydebruyne
Has thanked: 3 times
Been thanked: 4 times
Post by jaydebruyne »
I just wanted to ask you kitchen fitters a question:
I'm getting into plumbing and wanted to know, when plumbing has been concealed behind or within kitchen units and access is impossible, what options are? Dismantle the units to get access?
I need to look at a tap which has been boxed in because of the kitchen units and currently there is no way for me to get any type of tool to the tap backnut.
Many thanks in advance for any help you can give.
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: Plumbing and Kitchen Units
Post by philprime »
I'd say sloppy fitting in the first place
If you can't get any tools to it you don't have much choice than remove the cabinet
jaydebruyne
philprime wrote:I'd say sloppy fitting in the first place
That's what I feared.. And that's quite difficult to do isn't it? Don't you have to remove the worktop first?
philprime
Post by philprime »
You will find that most kitchen units are screwed in to the worktop from the inside of the cabinet, a good fitter will also screw the cabinets together I always put my fixings behind the hinges
Once you have removed the screws take the kick board off and wind the legs down and you will be able to slide the cabinet out
These users thanked the author philprime for the post:
jaydebruyne
jaydebruyne
philprime wrote:You will find that most kitchen units are screwed in to the worktop from the inside of the cabinet, a good fitter will also screw the cabinets together I always put my fixings behind the hinges
I'm hoping when I go to have a look they'll be a simpler solution. I'll find out Thursday morning :/ But thanks so much for the info, it's a big help ;)
philprime
Post by philprime »
You may find there is an easier option good luck on Thursday
jaydebruyne
joinerjohn
Has thanked: 17 times
Been thanked: 315 times
Post by joinerjohn »
Was once asked if I could replace one kitchen unit (under the sink) Plumbing came out of the wall, then tee'd off in both directions, through holes drilled in the sides of the unit. The waste disappeared through the base board of the unit too. :lol: :lol: :lol:
Even Harry Houdini couldn't have replaced that unit. :wink: :wink:
jaydebruyne
Wow, you have to admire the art in his work :P
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
just hope the cab is not screwed to the wall or worse.... screwed to the next cabs on each side in the service void,(like i do)
you could look se if it had a removable back, or smash that back out and fit a new removable access panel/back
jaydebruyne
speed wrote:just hope the cab is not screwed to the wall or worse.... screwed to the next cabs on each side in the service void,(like i do)
What I don't want to do is remove a piece of wood and the units come crashing down! Dramatic I know but it's my first plumbing job so I want to do it right.
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
worst case. and if ya know what make of kitchen it is price for a replacement unit incase you have to knacker the old one to get to the tap nut.
seems strange you cant get to the tap nuts like.
jaydebruyne
fin wrote:worst case. and if ya know what make of kitchen it is price for a replacement unit incase you have to knacker the old one to get to the tap nut.
I've done the job now. I was able to get to the backnut, but it took a while to get it off. It was housed behind a sheet of 18mm marine ply which had barely been made accessible.
Mole grips and patience and the nut was off ;)
fin
Post by fin »
ahh well nice one. :thumbleft:
Return to “Kitchen Fitting”
