Spot replacement of tiled wall?
TigerUK
Has thanked: 37 times
Been thanked: 15 times
Post by TigerUK »
Planning on replacing the bathtub which is starting to fade (no longer white - the grey primer is starting to show now)
We have the wntire wall tiled. Unfortunately the dimensions of tiles cannot be found but there are slightly larger and thicker tiles available (same pattern) so hopefully they can be cut and used.
First question: Can tiles be cut neat enough and straight enough to align together or are they only suited the cutting to fit into corners and edges?
Second question: Is it possible to just remove one row of tile and remove all the plaster without knocking off the row above it? I am a bit concered that if I try to chisel away the tile cement that it will knock the tiles above it loose.
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Spot replacement of tiled wall?
Post by wine~o »
answer to both questions is "Yes" within reason...a wet tile cutter will help get the larger tiles down to size accurately..
Removing the old tiles needs to be done Caerphilly (Cheesy I know... :error: )
Get a grout rake and remove the grout first...then carefully chisel out the old tiling...PPE goes without saying.(Specially the eyes)
Return to “Tiling Forum”
