Hi there,
I have a fitted fridge on an all in one hinge in my house, but the door is wobbling slightly as there's only one bracket holding the fridge door to the unit door (pictured). Does anyone know where i can buy this bracket as I can't seem to find it anywhere and am keen to fit a few more to stabilise it!
Regards,
Jonathan
mystery integrated fridge bracket
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: mystery integrated fridge bracket
I'd imagine there should only be one bracket - it looks like it's slides with the door. If you've got multiple, they would all have to be aligned bang on or the door would stick.
Have you tried putting the missing screw back in first?
BG
BG
- Has thanked: 1 time
Hi and thanks!
Thankfully it's not a sliding door - the fridge door is just mounted onto the door unit with clips at the top and bottom to hold the weight. However, because of the construction of the kitchen unit the door is bending when we open it because there's only one of the clips at the bottom and not at the top (pictured). Agree there should be another screw which i'll fit, but the clip itself doesn't move so i'm not too worried about it at the moment.
Regards,
Jonathan
Regards,
Jonathan
- Chris Skilbeck
- Has thanked: 132 times
- Been thanked: 238 times
Hi, and welcome,
Maybe the door wouldn't wobble if you put the single bracket about half-way up, instead of near the bottom. I guess the ideal position for the bracket would be about level with the door handle.
