Oak computer desk in a tight corner
mailee
Has thanked: 1 time
Been thanked: 69 times
Post by mailee »
I built this computer desk and got it installed today. Glad to say everything fitted just as planned. It was a tight corner due to the radiator and associated pipework. My customer wanted as much of the computer system 'in' the desk so I came up with this design with a slide out section for the printer and speaker control unit.
Never enough hours in the day!
http://www.alanwilley.co.uk/
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Re: Oak computer desk in a tight corner
Post by EJJ150847 »
Like the slide out printer stand
Excellent job as always Mailee :thumbright:
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Very clever Alan, (and I'm glad I saw the second pic before putting my foot in my mouth)! Like, where do you put your legs .:lol:
I'm guessing you must have worked out that the runners will take the weight OK?
mailee
Has thanked: 1 time
Post by mailee »
Thanks guys. Yes Ayjay, the runners will take a 50kg load so no problem. I did tell the customer not to lean on it though. :lol:
nick200
Has thanked: 409 times
Been thanked: 222 times
Post by nick200 »
Looks very good, I like it. :thumbright:
I also almost put my foot in it by asking why no lid on the printer area but you would need access!
Nick
Retired
Has thanked: 2019 times
Been thanked: 588 times
Post by Retired »
Very well done mailee; an elegant solution to a tricky problem in making so much use of such limited space; the idea could also be applied to a kitchen bar where space is tight? Neat job and well thought out.
Kind regards, Col.
Return to “Show Case Gallery”
