Milwaukee M12-M18 mulitipurpose charger
Posted: Fri Oct 03, 2014 12:26 pm
The Milwaukee M12-M18 charger is an ideal solution for charging Milwaukee 12v or 18v batteries from the one charger.
The main advantage is that you only need the one charger to charge the two different voltage batteries which makes the job a lost simpler if you have to get your charger PAT tested before use on site.
It charges the batteries on a first come first charge basis, so the first battery inserted will be the first to charge.
The unit can charge a 3ah battery in approximately 60 minutes and a 1.5ah battery in approximately 30 minutes.
