Double gates
mailee
Has thanked: 1 time
Been thanked: 69 times
Double gates
Post by mailee »
I have just finished making these gates over the last couple of days. now I am praying for some good weather to get them fitted. :roll:
Never enough hours in the day!
http://www.alanwilley.co.uk/
Retired
Has thanked: 2019 times
Been thanked: 588 times
Re: Double gates
Post by Retired »
Lovely job mailee and I hope you can finish them in spite of the bad weather; are you going to finish them before hanging then you can do this indoors out of the rain? What finish are you going to use? Keep up the good work and thanks for sharing.
Kind regards, Col.
mailee
Has thanked: 1 time
Re: Double gates
Post by mailee »
No Col, the customer is going to put the finish on. I have given them two coats of a clear preservative as I do for all of my outdoor work, but I think the customer is going to colour them a bit darker like the old gates I am removing.
These users thanked the author mailee for the post:
Retired
Chop
Has thanked: 304 times
Been thanked: 219 times
Re: Double gates
Post by Chop »
Lovely work Mailee - :thumbright:
What sort of hinges will you be using on them?
:thumbleft:
mailee
Has thanked: 1 time
Re: Double gates
Post by mailee »
Thanks Chop, I shall be using large band hinges for these.
nick200
Has thanked: 409 times
Been thanked: 222 times
Re: Double gates
Post by nick200 »
Looking great mailee :thumbright:
Nick
Sean-edwards
Has thanked: 6 times
Been thanked: 2 times
Re: Double gates
Post by Sean-edwards »
Looking good! :thumbright:
Return to “Show Case Gallery”
