Got new tiles Need grout advice
Posted: Sat Oct 18, 2014 4:48 pm
by scotty1989
Got new tiles and was wondering for advice on the grout and adhesive to buy and where to buy it,
also could get the same advice for beads
how much grout and adhesive would I need also ruffly 11m2
Re: Got new tiles Need grout advice
Posted: Sat Oct 18, 2014 4:53 pm
by royaloakcarpentry
What tiles, what size, where are they for, what is the substrate they are going on????
Posted: Sat Oct 18, 2014 5:00 pm
by scotty1989
oscano stone cermanic tile
30x50cm for both wall and floor and will be going onto a gyproc wall
Posted: Sat Oct 18, 2014 5:33 pm
3 bags of rapid set adhesive. BAL, NC amd Mapei all good makes....The Mapei is probably the easiest to mix by hand. Tiles will need to be back buttered or DIY install. DIY install may put you into 4 bags of adhesive.
Grout I think would be 5kg. I just know which size to pick up lol. ( I haven't even got a clue how much a bag of adhesive weighs, just know how many).
Trims will be a couple of mm thicker than the tile.
Bear in mind suitable substrates and weight limits.
Posted: Sat Oct 18, 2014 6:01 pm
by darrenba
royaloakcarpentry wrote: I haven't even got a clue how much a bag of adhesive weighs.
20kgs :)
I'd go for standard set, rapid set goes off too quickly for DIY installs.
Posted: Sat Oct 18, 2014 6:11 pm
by steviejoiner74
If the floor is chipboard you should really overboard with some tile backer board(6mm I think?) or plywood. The tilers on here will say minimum 15mm ply but we use 9mm on top off 22mm chipboard Screwed every 150mm and have never had an issue. You can tile on top of chipboard if it's prepped correctly and I've seen many many floors tiled directly onto chipboard with no issues that've been down 20+ years.
The problem is lifting tiles from chipboard in later years,it completely wrecks the floor in the same way tiling onto plasterboard does.
Posted: Sat Oct 18, 2014 8:25 pm
by scotty1989
Am not sure what is underneath it as ave not lifted the old tiles yet still to get a suit for the bathroom too struggling to find on I really like
