Hi all,
I need to buy a new tile cutter as the one I have now spits water out all over the place, making using it indoors a pain in the a***!
So wondered if anyone has any suggestions on which one I should be getting...
Tiling is something I do everyday but I do it often enough to appreciate my electric tile cutter and as I already have a manual one that I rarely use I'd like to replace the nackered electric one, preferably without spending a small fortune but nothing to cheap and crappy either.
So any help, suggestions etc would all be welcome! Thanks
Which tile cutter?
- Megaross
- Has thanked: 28 times
- Been thanked: 110 times
Re: Which tile cutter?
I've got one of the Titan ones from screwfix which got plenty of use a few years back, probably fully tiled about 20 reasonably sized bathrooms with it as well as a few odd jobs (splashbacks etc) and never had a problem with it. Better than the wickes own brand one that it replaced.
I'd probably be inclined to get a Titan because they're cheap enough to bin should they go wrong but not so cheap it's a piece of junk to start with.
