Hand rubbed French polish finish.
Retired
Has thanked: 2019 times
Been thanked: 588 times
Post by Retired »
The following is an extensive restoration I carried out on a genuine antique wooden clock case. Quite a while ago whilst visiting a friend I was asked if I would have a quick look at his old clock which he thought "needed a bit of work"? We lifted the clock out of the gloom to where I could inspect it more closely in better light. At first glance I thought its not too bad and will be easy to fix but as I looked closer at it I saw the many problems and these problems were not at all small. It suffered from split and missing veneer; the top panel was badly cupped; one of the top joints had opened up in fact I said why not throw it into a skip; although a genuine antique it's value and rarity was not high. My friend would have struggled with this restoration and would have little chance of applying a decent finish because I had already seen his previous work.
Like the sucker that I am I said pull the works out and let me have a go at the case restoration and you being the clock expert can sort out the mechanism; I had never attempted restoring a clock case previously but I had restored many vintage radio cabinets. With the clock home and on the bench I removed the door because to damage this or break the antique glass would see the end of this job. With the door safely out of the way I thought what have I taken on as I looked at the bare case. It was a wreck with no redeeming features whatsoever so whatever I did to it wouldn't hurt it much further? The bottom sections had also started to come apart.
I had been given full permission to do whatever I wanted to this clock case so looking at its sorry state I decided the best way to proceed would be to remove all the old battered veneer and start over. The old veneer had been installed with hot hide glue which pleased me but it was still a right pain removing it and little by little I steamed it off in small strips. With the veneer removed it revealed extensive damage to the front top panel in fact part of this panel fell off to cheer me up. I re-glued the panel but the panel was badly deformed with a large prominent cup towards the front and one of the side joints had also broken. So it wants to play games with me does it? A good smack with a hammer had the top panel removed saving lots of fussing around. The broken joint looked a right mess but at least the two parts were still there.
Clock 4.jpg (324.42 KiB) Viewed 3691 times
Clock 6.jpg (290.1 KiB) Viewed 3691 times
Clock 7.jpg (289.41 KiB) Viewed 3691 times
When I had removed the veneer I went over with a very sharp cabinet scraper bringing the case down to clean bare timber; it's worth mentioning that the case was made of nothing more than common softwood including knots. The inside was brushed and de-spidered using a vac so now it was already looking cleaner even if I had destroyed it. The front top panel and broken joint was my main concern at this point; the original top panel would never look good again so I looked around the offcuts I had and found the perfect bit of genuine antique plywood of exactly the right thickness to allow for a layer of new veneer. I heated up the hide glue and made good the joint and at the same time installed the new plywood panel I had cut out using the bandsaw. The panel and joint were very carefully aligned then gently clamped leaving the clamps in place overnight.
The following day I was keen to remove the clamps and when I did this cheered me up; the broken joint was now totally invisible having gone back together perfectly. I then sorted the bottom section using hot hide glue and clamping which took care of that. I like using hot hide glue but this glue takes a bit of getting used to because it gels very quickly so speed is needed during a glue up. If hot hide glue is used the joints should stay together for hundreds of years because it is a terrifically strong glue; it sets rock hard and doesn't creep but even after 100 years it can still be softened. Hide glue is cheap and a double glue pot doesn't cost a fortune; mine cost £20 through eBay and has earned its keep many times.
Clock 5.jpg (310.74 KiB) Viewed 3691 times
Clock 10.jpg (290.26 KiB) Viewed 3691 times
With the case nicely cleaned up and ready to receive new veneer Bron and I had a trip over to Craft Supplies in Derbyshire; the only veneer in stock which looked of use for this job was Australian Walnut but it was incredibly stripy but I had little option so bought two pieces costing about £12 the two and we returned home; I had bought just enough veneer for the job so took a lot of care in marking and cutting because another trip to Craft Supplies would be needed if I made a silly mistake. The veneer was measured and measured again then cut slightly oversize then it was attached using hot hide glue; once the glue had set the excess veneer was carefully removed and all sharp edges were eased.
Hand sanding followed going lightly because modern veneer is very thin; this was followed by Vandyke stain and was left overnight to completely dry. I was pleased once the stain went on because it killed the stripyness of the veneer. Next job was to apply the finish. I had chosen French polish (shellac); I applied the polish but wasn't at all happy because for this application it was much too shiny often referred to as a "toffee apple" the more I looked at it the more I disliked it so decided to give it a matt finish to see if it would look any better? I used "0000" grade wire wool wetted with liquid paraffin as a lubricant and gave the polish a good going over working with the grain but taking a lot of care at edges not to cut through to bare veneer. Wiping off revealed a perfect finish in keeping with such an antique; I was pleased.
New veneer fitted..jpg (910.15 KiB) Viewed 3691 times
Vandyke stain added. (1).jpg (973.21 KiB) Viewed 3691 times
Clock 11.jpg (277.85 KiB) Viewed 3691 times
Clock 12.jpg (341.86 KiB) Viewed 3691 times
With the bare case now completed I wanted it off the bench and out of the garage so set off to my friends to deliver it; unfortunately it was rush hour and the short journey took about three quarters of an hour; When I arrived at my friends I felt tired out but was greeted by it's just about teatime? I said I'm not intending to stay so dropped the case off and departed to face more gridlock on the way home; at least the bare case was now out of harms way and I could now concentrate on restoring the door. The door glass was filthy so I very gently cleaned it best I could but my friend said not to worry about the glass too much because he was happy to spend time cleaning it. The original finish was completely removed down to bare timber then as before it was sanded and stained. This time however I thought I'd try a new method of applying the French polish and if it worked it would not only save me a great amount of time but could be used on other projects of similar nature?
I applied the French polish using an artists #2 fan brush building layer on layer until a good thickness had been built up this was then left a full day to fully harden; next I simply went over using the wire wool and liquid paraffin; it worked a treat in fact I couldn't believe how quickly I had achieved this beautiful finish? This was a revelation to me; looking at the hand rubbed finish I thought that was incredibly easy to achieve and it looks as though I've spent hours working on it; French polishing proper takes much longer to achieve if the mirror finish is desired but for this clock case the hand rubbed finish suited it perfectly. The inside of the clock gave its antique age away and now the outside although factory fresh looked as though the clock had been cared for all its life and once dirt accumulates in the corners it will look genuine? What a delightful job this had been for me and I enjoyed the challenge. I returned the door and asked my friend to please take some pictures of the finished clock and send them by email? I didn't charge a single penny for either materials or labour after all I had enjoyed the pleasure of doing the job and it was for a friend.
Clock 15.jpg (319.88 KiB) Viewed 3691 times
Clock 14.jpg (314.95 KiB) Viewed 3691 times
Clock 13.jpg (285.04 KiB) Viewed 3691 times
A few days later I received about a dozen pictures from my friend by email; eleven of the pictures were in perfect focus of his work on the mechanics and one extremely bad picture of the completed clock without it even having had the glass cleaned. My friend is no more and I won't be interrupting his tea time whilst doing him a favour!!!!
Clock 17.jpg (333.17 KiB) Viewed 3691 times
Clock 16.jpg (215.25 KiB) Viewed 3691 times
Clock 18.jpg (127.83 KiB) Viewed 3691 times
I hope this is of interest. Please note difference in quality of the two last pictures; had I known I would have completed the case assembly at home and taken finished pictures of it but alas it is now history and I've done many projects since then.
Kind regards, Col.
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Re: Hand rubbed French polish finish.
Post by wine~o »
Wonderful work there :salute:
Retired
Chop
Has thanked: 304 times
Been thanked: 219 times
Post by Chop »
Fantastic, I find it fascinating that a heavy lathe man like yourself and also be delicate enough to do jobs like that.
Would you like to share your secret for a super sharp cabinet scraper? I'm a recent convert myself thanks to Job and Knock. :huray:
Top work matey :salute:
These users thanked the author Chop for the post:
Retired
:thumbleft:
Retired
Post by Retired »
Thanks wine~o; much appreciated.
Many thanks Chop; yes I can be very delicate when needed and have immense patience once I start one of my projects. I can let out my frustrations using the lathes etc then I'm calm for the jobs requiring a light touch; I'm never bored although I detest these short days which prevent me from doing so much more.
Regarding sharpening a cabinet scraper; never run your finger along the edge or the sharp scraper will turn a lovely shade of red and you won't feel a thing;
Here are a couple pictures showing how good a simple cabinet scraper can be once correctly sharpened; I'm bringing inlaid stringing down flush. I also have a Stanley #80 which will quickly bring a sawn board down to silky smooth ready to receive finish. Beats the heck out of sandpaper.
Kind regards, Col.
Hand scraping 1.jpg (391.9 KiB) Viewed 3618 times
Hand scraping 2.jpg (360.43 KiB) Viewed 3618 times
Stanley #80 scraper.jpg (327.77 KiB) Viewed 3618 times
Chop
Post by Chop »
I watched the very same vid and linked it in my thread, works for me too. Is that a veritas one?
:thumbleft:
Retired
Post by Retired »
The handled scraper in my picture Chop is a Stanley #80; my other flat card type scrapers are a mixture because I always have a selection ready sharpened to hand. The #80 is rather too fierce for delicate work but is very handy for roughing down and this #80 has a different blade it being sharpened on one side only rather like a plane blade but with a burr added. Have you seen this video showing a Stanley #80 in action; if not it clearly shows how quickly this scraper works;
Kind regards, Col.
dandan
Has thanked: 10 times
Been thanked: 54 times
Post by dandan »
Brilliant work
These users thanked the author dandan for the post:
Retired
Retired
Post by Retired »
Thanks dandan; I wish it was warm and dry all year round then I could really enjoy myself with my assorted projects. It's cold this morning and although I'm working indoors I'm waiting for the bedroom to warm up before making a start; I don't like being cold.
Kind regards, Col.
Return to “Show Case Gallery”
