Router Cutters
- Teabag
Router Cutters
Just curious if people have particular prefrences with all the brands of cutters avaliable.. what do you use...
my own personal opinion is this...
I try to always use tct cutters, and always avoid high speed steel cutters, Im not bothered about using a certain brand, I couldnt care less if I bought a box of 20 cutters all tct for a fiver, if that box happened to have the profile I wanted and did the job I required it for thats good enough for me... however I do always look at the build quality, the cutting edges of the cutters make sure they have no chips or damage on them, I also make sure the bearings are ok too...
I've been down the path of buying expensive sets for a few cutters and wont do it again as they dont get the use to warrent the expence.
for worktops I use a throw away tip style, made by trend.
whats your views...
whats your views...
If you can't convince'm with arguments,
dazzle'm with bullshit
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
i buy every reduced price router set i see
and the ones you use the most you buy a decent one and spend £7 to £25 on buying a quality cutter
i have over 300 router bits around 50 are expensive[more than £5]average around £12
i like freud trend tornado
http://www.rutlands.co.uk/cgi-bin/psPro ... &Submit=Go
- Teabag
fair play...
Unfortunatly I dont get much oppertunity to play with my own routers, I only have a few sets of cutters, I use a beast of a machine at work every day, same old cutter in it (replacable tip) for cutting through worktops or making bolt routings, feel like im a dust monster most days...
- big-all
- Pro Carpenter
ok what i was realy saying was
you buy a 40 piece s/f or machine mart set for £50 you work it to death so you will have used about half the 40 cutters of the 20 you regulary use 10 will be used 1 to 5 times a month so the set cutters will be fine as they are occasional use
of the other 10 5 will be medium use so on the list for future decent cutter
the other 5 will be definate "decent cutter list
- Has thanked: 77 times
- Been thanked: 335 times
I have a couple of 1/4" sets, 10 cutters for £15 type, and a big set of 1/2" unbranded ones. About 30 cutters for £30. Anything special, i normally get screwfix, faithfull or from Axminster's perform range.
I think theres one or two trend craft ones in there aswell. But only beceause thats what was available when i needed them.
The cheap ones are adequate for my needs. When they dull, just touch them up with a diamond lap.
Very easy, just do the back of the cutter rather than the edge.
- Has thanked: 823 times
- Been thanked: 3560 times
I similarly have a lot of cheap cutters but you get what you pay for. I have bought some Tornado specials from Rutlands when they are on offer, such as door and box making sets, and they have been good.
It depends what you are cutting I guess, I do not mind dulling a cheap cutter on a job but I think twice about using the more expenisve ones.
- Has thanked: 16 times
- Been thanked: 9 times
