LIGHTS TRIPPING OUT
Locked
chris 1956
LIGHTS TRIPPING OUT
Post by chris 1956 »
HI MY WIRING INMY HOUSE IS CAUSING ME PROBLEMS WHEN I TURN ON MY CEILING LIGHTS THEY COME ON BRIEFLY THEN GO OFF MY FUSE DOES NOT BLOW AND THE SWITCH ON MY BOX REMAINS ON IF I LEAVE LIGHTS SWITCHED ON AND TURN ELECTRIC BOX OFF AND ON THEY THEN COME ON MY ELECTRIC BOX IS THE OLD STYLE WHERE YOU REPLACE THE FUSE WIRE WHEN IT BLOWS OH THE PLUG SOCKETS STILL WORK WHEN THE CEILING LIGHTS GO OFF THOUGH. ANYBODY ANY IDEAS.
PJ
Post by PJ »
Hi Chris
I came across a similar problem for a customer a few years ago....the cause being a very small break in a live conductor feeding a lighting circuit that opened up as the conductor heated during use and broke the circuit (i'm not saying this is your problem...but it is possible).
The rewireable fuse would only blow if you had a short between conductors on a circuit (if at all as rewireables have to take a large load...and go with a real bang).
The sockets will stay on when the lights go off as they are fed from a different fuse.
You really need to get this checked out by someone experienced in fault-finding as they normally have the equipment necessary.....and please consider getting your consumer unit replaced for a modern one....so much safer for you and/or your family
time is a great teacher....unfortunately it kills all its students!!!
Locked
Return to “Lighting”
