Socket hole in tiles not big enough, what do you recommend?
- Has thanked: 8 times
Hi, the hole I cut in my tiles isn't quite big enough for the socket plate to fit in so I need to make it bigger.
What would be the best way to do this?
I have an SDS hammer drill (Bosch PBH 2100 RE) but I don't think I can get a tile cutting drill bit for it.
Do I need to buy a drill? And if I do, any recommendations?
Thanks,
Arty
Thanks,
Arty
- IMG_2672.JPG (59.94 KiB) Viewed 3089 times
- Has thanked: 108 times
- Been thanked: 1038 times
Re: Socket hole in tiles not big enough, what do you recomme
Since you haven't grouted you could pop out the tiles and re-cut? I would only do this if I had spares though, could be easy to break it.
If I were doing it myself I would put a tile cutting blade in my dremel or multitool, but obviously you need the relevant tooling to do that.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
I would pop the tiles off and recut them
- Has thanked: 820 times
- Been thanked: 3519 times
Surely yo only need to cut a small part of the tile to allow access to the screw tab? I have done this myself as I did not notice the tab when fixing the tile as I had paper covering the wires. I used my tile drill and cut two holes and gently tapped the tile away. It worked quite easily and the socket cover went over to give a nice clean finish.
- Colour Republic
Looking at the hole its a height issue DWD, the body of the socket won't go in, by quite some margin it looks
Have I missed the point? I was under the impression that the box is already there as I can see a tab. Surely the socket cover sits above the tiles? As I could not see the second tab I thought that this is what the OP meant?
- Has thanked: 16 times
- Been thanked: 28 times
It'll be the housing on the back of the socket cover that won't fit.
A socket cover from a different manufacturer might fit, i.e. one wth a housing that doesn't come as close to the edges?
If not, would a spacer plate (10/12mm) work?
- Has thanked: 19 times
- Been thanked: 21 times
