REAL high power LED floodlights
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Anyone got any pointers to industrial quality 150W LED floodlights?
I have to fit EIGHT of them to mobile towers and the basic cost of £350 each sort of makes me squint......
Looking for a discounter rather than a cheap'n'nasty solution.
TIA
TIA
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
Re: REAL high power LED floodlights
thats around 10.000w equivilent or around 130.000 lumens for 150x8
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
Are you paying for them? some one must have specified those particular lights for a reason, quality?
- kellys_eye
No, I'm not paying (maybe I'll have to purchase them and invoice the client though) but they are for diesel lighting rigs used in a local quarry. I have four sets to refurbish each with four lamps and they want LEDs in place of the current tube devices - one set has already been done.
- Someone-Else
Sorry if I am missing the obvious, but if you are not paying for them why would you want to "not pay" less for them?
If they are happy with the ones they have now, why not use the same again as:
1) They are paying for them
2) The new ones will be exactly the same as what they have got, so there can be no grounds for an argument. I.e wrong colour temp, not the same physical size, not as bright etc
- kellys_eye
Fair point - but I don't consider just paying whatever someone demands for a product, just because someone else is paying for them, to be the right thing to do. I will at least try to save them some money. It's called 'customer service'. Ever heard of it?
- Someone-Else
I was not being or trying to be sarcastic. Sorry if you thought I was being so.
I am trying to save you grief from the customer complaining that the new ones are a different colour or smaller or bigger etc than the ones they have.
They are happy with what they have got so why not buy them more of the same. Realistically what would you be hoping to save them in terms of money, £5-10 / fitting would not be worth it even if there are 8 to be had, since by the time you add "your bit" on (still no sarcasm) in the over all scheme it would not be that much. now if you could save them £50 / fitting yes, that would be worth it, but that would only end up taking you down the "cheap road" which no one wants to do, which to me takes us back to where we started, they are happy with what they have, they are happy to pay for them, buy them some more of the same.
The only other option I can suggest is to buy multiple fittings with lower wattage that cost considerably less / fitting, but I would assume that for what ever reason (I don't need to know) that this would be impractical.
- Has thanked: 61 times
- Been thanked: 319 times
No expert but I would have thought industrial quality outdoor use ones would not come cheap have you tried contacting
Dialight
http://uk.dialight.com
or
Gemma Lighting
http://www.gemmalighting.com/products/ledfloodlighting/
Are these any use at about £300
http://www.ledlightingandlights.com/out ... tAodplUAkQ
Le have one for about £190
http://www.lightingever.co.uk/150w-high ... ts-dw.html
Good luck
Dialight
or
Gemma Lighting
Good luck
- kellys_eye
Thanks for those interesting links - there's a couple in there that I'll be investigating
- Has thanked: 247 times
- Been thanked: 314 times
£230
http://www.ebay.co.uk/itm/10w-20w-30w-5 ... 1e80d47551
Also try CEF...they were sending me emails with details about their marine grade high power LED floods a while back
Gone M.I.A.
http://www.inui.co.uk/ip68-marine-grade ... -150w.html
http://www.dakal.co.uk/furrud-led-floodlight
http://www.netledlighting.co.uk/led-lig ... lood-light
- These users thanked the author scot-canuck for the post:
- kellys_eye
Gone M.I.A.
