Stone tiling on stud fireplace.
somapop
Has thanked: 81 times
Been thanked: 12 times
Post by somapop »
Hi all.
I built this stud fireplace last year with a combination of stud work (various sizes of wood - it's absolutely solid - and plasterboard), and then had it plastered before painting it up.
Had the choice of either keeping it as it is, wallpapering it or adding stone tiles to it. The last choice has proved most popular (the other half rubber stamping it too).
The tiles I really like are those really thin, rectangular ones as in the examples below:
Erring towards the more clean lined versions of stone tiles/clad rather than the overtly 'rustic' and I'm very conscious of costs too.
I happened on a few in Wickes, whilst browsing for something else recently. These seemed to be set in sheets (I guess you'd cut the backing depending on the area you're cladding. But aside from that I haven't actively looked into them. I've tiled a bathroom a few years back (applying less critically than I would do today!) and have an oldish tile cutter (still works, albeit noisy and messy!).
The last pic is of my fireplace. Tricky bits might be around the speaker sections as there's not a lot of space to play with (thin sections).
Any tips and suggestions would be most appreciated.
Cheers!
False Fireplace.jpg (208.23 KiB) Viewed 4682 times
somapop
Re: Stone tiling on stud fireplace.
Post by somapop »
Apoloiges for dragging this one from the depths...but I literally can't find any starting point on tiling this way. I had a quick look in Wickes/Selco etc, but they don't seem to stock these type of thin tiles (wickes had something similar but hugely expensive).
Does anyone know of a firm that sells these type of stone (or ceramic) thin tiles like in the pics above and this one below:
Any advice (techniques etc) would be hugely appreciated.
Cheers.
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
I am probably well late with this but try ***** www.*****.com.
EDIT: :error: :blah5:
OK p o r c e l a n o s a and I don't have shares in it.
Return to “Tiling Forum”
