Lathe headstock repairs.
- Retired
- Has thanked: 2019 times
- Been thanked: 588 times
I've mentioned in previous threads the rare Myford MF 36 I bought and eventually found to be a heap of scrap once I got it home onto the bench. I had bought the MF through eBay paying a lot of money for it so I didn't want to scrap it after all my background is mechanical engineering so I set about repairing it. Normally when a lathe is this damaged it pays to scrap it but I like a challenge and I wanted to know if I could still do hand work to very close tolerances?
The main headstock casting had fractured across the rear of the main front bearing obviously allowing the mandrel and chuck to vibrate badly once a cut was applied. This was very bad news but all was not yet lost. I had made and installed a temporary repair this being a metal clamp secured with machine screws after firstly drilling and tapping; I measured the bearing and the overall area affected then visited Blackgates Engineering and bought two over size Meehanite (cast iron) blocks to use as blank bearing caps.
What followed was a lot of work. I used the Myford to repair itself by facing both blanks very accurately then in turn they were opened out for the bearings using a boring bar; this sounds easy but the MF was miles out regarding accuracy; once the facing had been completed I had to re-adjust the headstock to allow the boring to take place with great accuracy; I can work at home to a tenth of a thou and with masses of patience taking lots of time I produced two bearing caps machined accurately all over and with the bore to accept the half bearing.
Bron and I visited Plastics Online in Sheffield where we bought an oversize diameter of round Whale Tufnol at 6" long. I had already been in touch with Tufnol enquiring how much they would charge just for the single bearing I needed; at £150 I wasn't amused. The Tufnol cost around £20. Back home I set about turning two headstock bearings; after all I might as well do the job right first time. I had never previously turned bearings from Tufnol but I found with a lot of care and patience Tufnol is a delight to turn if somewhat dirty.
Now after many hours work I had two new bearing caps and a pair of new Tufnol bearings. I had profiled the two caps the hard way using hacksaw and files to make them appear factory items. With this done I could now remove the headstock and set about removing the top half of each bearing? This was difficult and made my arms ache again only using an hacksaw and files; I had been taught to file flat to a thou of an inch so this was a good time to use the skill. The results can be seen in the pictures using very basic hand tools. The headstock was drilled and tapped to accept machine studs and nuts for securing the caps. The new bearings were cut in half and after lots of test fitting the lot suddenly came together and I was well pleased with my efforts. Once I had turned the new bearings I took the bearings and mandrel over to Metalizers a few miles away. The mandrel was metal sprayed in hardened stainless and brought back to original specification; my new bearings were tested to be a very accurate fit. The MF was reassembled and was run on test for a couple of hours where the bearings heated up at first but with plenty of lubrication and a bit of tweaking on the adjusting nuts it settled down and shook hands with me at last. I never did like this Myford although I was offered a clone and also bought this; after spending around £400 on bed regrinds I decided whatever I did to these lathes they would still be old lathes so I sold them both through Bay losing around £1,000. I had spent many happy hours tinkering around with them and enjoyed using my old skills so didn't begrudge losing the money too much but better to quit now than sink even more money into their restorations.
A few months later I was fortunate enough to buy a very rare Lorch Schmidt precision engineering lathe at price to make up for my loss on the Myford's so I was well pleased and have subjected the Lorch to a comprehensive restoration it now being a much; much better lathe than the Myford's even when the Myford's were brand new.
I was taught at a time when apprenticeships were offered by most large companies; (early sixties) the National Coal Board was excellent in this respect and subjected me to lots of close strict training which to this day still proves so useful; I was taught to use my head and my hands and to think for myself; engineers make parts to fit whereas fitters simply fit ready made parts and between the two is a vast difference. I love making things from scratch keeping my old skills alive and would encourage anyone to have a go at impossible repairs just for the fun and interest; after all if something is broken it should with a lot of TLC only improve upon it? Just another little story whilst its snowing outside. Roll on the day I can work in comfort in the garage?
Kind regards, Col.
Kind regards, Col.
- These users thanked the author Retired for the post:
- ultimatehandyman
