Drill bits for making wooden plugs
Bludall
Forum Chatterbox
Has thanked: 39 times
Been thanked: 5 times
Post by Bludall »
I've been looking at a diy book from the library that mentions drill bits that drill out wooden plugs for hiding screws in skirting/ architrave, etc.
Up until now the oh has been putting dowel in the holes, cutting it flush and sanding it. I've decided that we need one or a set of different sizes. What should I be looking for regarding a good range of sizes, or could someone recommend a set?
Failure means you just didn't get it right yet!
Louise
skiking
Been thanked: 4 times
Post by skiking »
Bludall
Forum Chatterbox
Post by Bludall »
skiking
Thanks. Do you have a set from there?
I presume the set is a standard set of bore sizes and would cover all diy needs. :scratch:
Louise
skiking
Post by skiking »
I don't, no.
I just understood what you were after and did a quick look on screewfix. Always the first port of call :wink:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
Best reason for using these it that the plug matches the material being used.
I've used them to screw hardwpood skirting boards in place, using plugs from cutoff bits.
machine mart do a boxed set, not up to pasting links yet, cht367-8pc-drill-plug-cutter-set.
Remember when you were clever when you knew how to use a slide rule properly, and not just for drawing straight lines, well that's my era, old git!! comes to mind. :oops:
John
Bludall
Forum Chatterbox
Post by Bludall »
Thanks guys! :thumbright: Even I could do that. I removed all the skirting and have to put it back, so I wanted a neat looking finish using wood plugs. I just can't understand why I've never come across them before. Are they a new idea? :scratch:
I just looked on the Machine Mart site and saw this, so that'll be the one I'm getting tomorrow because i can get one from the shop and I think it's a reasonable price.
plug cutter set
Louise
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
That's the ones i used to have Lou, can't fault them. :thumbright:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Bludall
Forum Chatterbox
Post by Bludall »
I bought some Stanley toolboxes from B & Q for £10 for a big one and a small one and I'm going through the jumble that is our tool kit sorting them out, mainly so that I can find stuff. :thumbright: I'm buying useful things to add to the kit to make things less labour intensive and to make a more professional job.
Louise
Return to “Tool Talk”
