Diesel Oil ?? Citroen Berlingo Multispace 2.0HDi Desire
Mick Coleman
Has thanked: 2 times
Post by Mick Coleman »
Hi
I have a Citroen Berlingo Multispace 2.0HDi Desire
im getting low on oil
can anyone tell me what oil i need to put in the engine.
never had a diesel before.
PAINTER 1
Foggy
Been thanked: 1 time
Post by Foggy »
how old is the motor ?
i have a 07 Civic 2.2 diesel and honda recommed
Castrol Edge 0W30 or 10W30
or
Castrol Turbo Diesel 0W30
if your not 100% i would ask Citroen ,if its been serviced ,what did they put in
dont want to scare you here but if you have to claim for a knackered engine under warrenty and the wrong oil is in they will tell you to swivel :roll:
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Post by Cannyfixit »
Just pop into your local auto center they will show you which one you need,plus the containers are marked up as well
I use Shell 10W-40 in mine
Mick Coleman
Diesel oil
ok Thanks
I know you got to put in the right oil.
PAINTER 1
iceni
Has thanked: 1 time
Been thanked: 7 times
Post by iceni »
Just make sure it's an oil for diesels engines, they use a high detergent type oil that captures all the combustion particles.
Mick Coleman
Thanks for the replys
its a 2005 Citroen Berlingo Multispace 2.0HDi Desire
i know what to look for now.
PAINTER 1
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
When I got my wife's Fiesta diesel serviced at the local FMC dealer they gave me a small can of Shell oil if we needed to top up between services.
Peter C
The end justifies the means
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Citroen normally recomend Total lubricants.
Total Quartz 9000, 5W40 is the top quality reccomended i think, synthetic based.
A lot of the oil compaines have selectors on their websites, such as this-
http://www.shell.com/home/PlainPageServ ... match.html
These common rail jobbies are a bit more fussy than the normal deisels.
Its a bit of a myth about not mixing Synthetic and Mineral oils. Normal Synthetic oils are refined from mineral oil bases anyway.
The only ones they shouldnt be mixed with is Fully Synthetic oils, which are more commonly found in extreme usage conditions, like hi load gearboxes etc.
