- Ultimate Handyman Forum Index DIY Forum/Home improvement Carpentry/Joinery Forum Kitchen Fitting
- It is currently Tue Apr 01, 2025 1:30 pm
square edge worktop fitting help
Hi guys
I have a Howdens white glass effect square edge worktop to fit
Kitchen I U shaped on the right hand side it is full width on the left hand side it is wall units fitted on the floor so the worktop is going to be narrower
To fit the worktop will it need to be mitred or is it just a butt joint
Thanks in advance
Mick
Thanks in advance
Mick
mickb2005
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
Re: square edge worktop fitting help
On square edge worktops, you only need a butt joint.
philprime
- Has thanked: 32 times
- Been thanked: 816 times
are they the type of tops where you have a pvc edge strip rather than a lami edge strip?
fin
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Post by steviejoiner74 »
If they have a slight chamfer you need to mitre them.
steviejoiner74
they sound like theyll be the sort you put the smaller mason mitre on like. my jig doesnt have that capability though so i gotta just go with a standard mason mitre all the time.
gan canny with the tops if they are mirror chip. and watch the cutter. i found they chipped really easily
fin
- philprime
fin wrote:gan canny with the tops if they are mirror chip. and watch the cutter. i found they chipped really easily
I Always use a new cutter and take a shallow pass to cut through the laminate using dust extraction really helps, I just need a longer hose for mine as it's now to short
philprime
aye.. the one i did a while back. i had to cut this particular top with the top upside down. so it was right hand male joint. new cutter. when i cut through the top it chipped loads out on the work surface. i ended up cutting the joint 4 times before it was good enough. when id finished i looked at the cutter and it was propper hammered. only ever had it on that particular type of work top.
was using my extractor on the router that day too.
fin
- Has thanked: 35 times
- Been thanked: 257 times
if its pvc edging, it will peel off, and butt join the worktop
it will just need a small mitre on the pvc edging where it joins
speed
Have you done many like that then dude? I just did a standard mason mitre on the bench I mentioned earlier. I was at some point gonna get a different jig to allow me to do both types of mason mitre joint
fin
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Post by Job and Knock »
Both types of mason's mitre? Wossat?fin wrote:I was at some point gonna get a different jig to allow me to do both types of mason mitre joint
In the "olden days" before there were router jigs, mason's mitre joints were cut with a saw and cleaned up with a router and straight edge. The angled piece on the female part of the joint was awkward as you had to creep up on the fit with a combination of files, chisels and a shoulder plane - but it meant that you could cut a very small, discrete mitre on tops with a small edge radius. Not that I'd want to go back - a joint like that could easily take 1-1/2 to 2 hours in a tight kitchen. Small wonder that a lot of guys took the easy option and just cut a big mitre
Job and Knock
http://www.its.co.uk/pd/KWJ700-Trend-Tr ... KWJ700.htm
see how theres a different angle at each end?
use the shallow angle when theres a slight radius edge on the worktops. like a lot of howdens tops.
normal end for normal post formed type worktops.
however i just use my trend 1002 jig so i have to put the same on all the tops. or butt join em like speed said.
fin
- steviejoiner74
You never blagged a free jig from howdens fin? I've had mines about 6/7 years,I think it's a unika jig with howdens branding but it's a nice piece of kit especially for free!
steviejoiner74
not yet. ill get the little fella at the howdens i go to to get me one next time
fin
- steviejoiner74
I always try and get something off them when I buy a load of doors or the odd kitchen,even if it's a trade scew case or something!
steviejoiner74
aye they jus gave me a screw case like. they normally offer a screw case or a chissel set. i told em last time the chisels were rubbish like
fin
