Hi
I've fitted engineering wood flooring to a concrete even surface floor using the appropriate underlay etc.
I've prepped the skirting boards (sanded down) ready to refix to the walls, and I notice that there is a slight gap where the skirting board meets the wood floor. The gap is not always present, it's just at certain points on certain walls.
Exerting pressure downwards on the skirting does not push it close enough either, it's quite rigid.
My question is how do I best eliminate this gap so the finish looks good?
I include an image of the problem.
Cheers!
Eliminating small gap under skirting when re-fitting
- Has thanked: 16 times
- Been thanked: 9 times
- Teabag
hi, BitChain
not sure what you know and what you dont, so take into account you may already be aware of things mentioned in replies...
firstly all wood breathes, as it takes in moisture and dries out. so in effect you may always get a gap depending on climate conditions within the house or room. central heating on or of ect... causing expansion and contracting.
to get the best fit possible and even gap you could scribe the bottom of the skirting to the floor. so during any expanding the skirting would be a perfect even fit. (as mentioned above... this is an edit as there were no replies when i started to post).
the tip to get most downward presure is to rest another piece of wood ontop of the skirting to be fitted, angled down to the floor, (around 3ft or so long) so it creates a ramp. then have another person apply presure to this by partially standing on it, forcing it to the floor, while you fix it in place next to the point where presure is being applied.
hope that helps....
hope that helps....
If you can't convince'm with arguments,
dazzle'm with bullshit
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
