I have Samsung mobile. I have the "app" called WhatsApp (The app is very good) When I am out and about WhatsApp works fine, as soon as I come home my phone connects to my Wifi via "BTWifi-with-FON" if i use WhatsApp, it will not "send / receive" anything. However as soon as i change my Wifi connection to "someone-else" Wifi (which needs a password) WhatsApp works. my question is, why?
Email will work if either is connected, which to me makes it more confusing.
When is broadband not broadband? (regarding mobile phone)
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2571 times
- getthewheelsinline
- Has thanked: 224 times
- Been thanked: 182 times
Some wifi connections restrict access to various websites and apps. FON is probably just trying to limit data usage due to potentially large photos/videos being transmitted. BT should be able to confirm this is the case though.
Not sure if FON is a captive WIFI, but WhatsApp does not support proxy connections.
- Has thanked: 99 times
- Been thanked: 875 times
Re: When is broadband not broadband? (regarding mobile phone
bt fon and wifi is basically a free wifi hotspot your supplying to anyone in range, the hotspot works the same as any public hotspot it requires you to login via a browser to gain access with your bt details
bt homehub's are set like this as default, simply login it to the HH/Router and disable it
http://bt.custhelp.com/app/answers/deta ... ith-fon%3F
- Someone-Else
Interesting. Thanks
- Has thanked: 5 times
- Been thanked: 4 times
You should be connecting to your hub using the connection settings on the label found on the router, not via FON. You have a username and password for FON supplied separately but you have to log in to this each time you want to use it.
- Someone-Else
That is trueMagic Matt wrote: You have a username and password for FON supplied separately.
No I don't. THAT, was the problem, my phone always wants to log into FON even though I did not tell it what the FON pass word is.Magic Matt wrote: but you have to log in to this each time you want to use it.
