Which paint for my BBQ?
Maz123
Has thanked: 19 times
Been thanked: 23 times
Post by Maz123 »
I think I've posted this in the right place... if not let me know.
I have a metal BBQ which unfortunately spent a winter with a torn cover so some of the paint has flaked and there are some areas of rust... So wondered if there was a paint I could use to smarten it up a bit. The paint will be exposed to the heat, as some of the areas are around where the coal goes.
I'll stop rambling now and hope that makes sense.
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Re: Which paint for my BBQ?
Post by Timllfixit »
I used high temperature paint(I think it's for exhausts etc.) once and it worked very well. It was a while ago so it wouldn't surprise me if special Barbie paint is now obtainable.
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
High temperature paint is the thing to use, but beware, some are a lot more temperature resistant than others...
As with any painting, its all in the preperation, rub any rust and flaking paint down well, then paint.
Most have to be 'baked' within a certain time from application if you want it to work well.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
I use black spray paint 'designed' for woodstoves to good effect. Well, it works perfectly on the woodstove and the exhaust pipe from it! Should do just fine on a BBQ.
There are, as mentioned, colour high temperature aerosols made for car exhausts and I recall using them some 30 years ago ( :? ) when I was into rebuilding Chevvy engines - sprayed the exhaust headers and it was 'bullet proof'.
Maz123
Post by Maz123 »
Any particular brands you'd recommend?
Maz123
Post by Maz123 »
Hitch wrote:High temperature paint is the thing to use, but beware, some are a lot more temperature resistant than others...
Any idea what sort of temperature it'll need to withstand?
kellys_eye
1,000 deg C
Car exhaust paints and woodstove sprays will do this.
LocksOnline
Has thanked: 4 times
Been thanked: 1 time
Post by LocksOnline »
Hey Maz, Can you email me please, E-mail address removed. Mod 2. . I can't read private message yet on here as I am new :( Sorry for the delay!
Emily :)
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 570 times
Post by moderator2 »
@ LocksOnline. You really don't seem to understand the spirit of the forum. If you have a suggestion that will help, post it on the forum for the benefit of all.
One more post asking for personal contact and you'll be looking at a red card.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Funny thing. Years ago I used to run an old side valve BSA M21. They run quite hot. Normal "high temperature" cylinder paint hadn't used to last five minutes around the exhaust port, and I tried some chalk board paint I had. (Don't ask me why I tried it. Can't remember. Short arms and deep pockets probably. :-))
Anyway that lasted for ages.
