Luxury Vinyl tiles in the bathroom
Posted: Sun Jun 14, 2015 10:48 pm
by el_mag
We have a sheet vinyl floor in our bathroom which the 'boss' wants changed to Limestone vinyl tiles. From what I have read once the sheet vinyl is removed, it needs 6mm WBP ply screwed at regular intervals. Special PS adhesive and then the tiles.
1) Do I need to put any DPM sheet under the ply?
2) Does the top of the ply need to sealed/feathered?
3) Are the vinyl design strips glued at the same time as the vinyl tiles or do use spacers and fill them later??
4) What colour grout strips look best with Limestone tiles?
5) The 'Boss' wants cream strips but I wonder whether the vinyl grout strips get dis-coloured just like normal grout??
Many thanks for answering the queries.
Re: Luxury Vinyl tiles in the bathroom
Posted: Mon Jun 15, 2015 9:09 pm
by Wes
el_mag wrote:We have a sheet vinyl floor in our bathroom which the 'boss' wants changed to Limestone vinyl tiles. From what I have read once the sheet vinyl is removed, it needs 6mm WBP ply screwed at regular intervals. Special PS adhesive and then the tiles.
What's the sub-floor, chipboard/floorboards/concrete/ashpalt etc?
el_mag wrote:2) Does the top of the ply need to sealed/feathered?
Yes. You'll need the use something like Ardex Feather or similar on all seams and screw/nail holes. Then it'll need rubbing down.
el_mag wrote:3) Are the vinyl design strips glued at the same time as the vinyl tiles or do use spacers and fill them later??
You'll glue the design strips as you go.
el_mag wrote:4) What colour grout strips look best with Limestone tiles?
Personal choice really IMO. I'd say a darker grout to accentuate the tiles but you could perhaps go for a light grey
It would be worth getting samples if possible to help with the choice before you buy.
el_mag wrote:5) The 'Boss' wants cream strips but I wonder whether the vinyl grout strips get dis-coloured just like normal grout??
Depends on the usage. They will dis-colour over time and with it being a light grout strip, you may see dirt grab in the seams between the tiles and the grout. A slightly darker colour would help.
Posted: Wed Jun 17, 2015 5:24 pm
by el_mag
Wes,
Thanks for your reply. The sheet vinyl is on top of floor boards.
I had a look at Ardex feather finish, it seems to come only in bags of 11 kg. Is there any other alternative as it's only a small area.
I agree that grey would probably be better with limestone tiles as i was worried the light grout strips would get dirty.
Thanks again
Posted: Wed Jun 17, 2015 6:06 pm
by NorthantsBen
Ultra floor patch it comes in 5kg bags.
I used to use it all the time when fethering ply etc ready for lvt / vinyl.
I like ultra products I use there two part latex and quick repair too.
Posted: Wed Jun 17, 2015 7:34 pm
by Wes
No need for a dpm then el mag
Posted: Wed Jun 17, 2015 8:49 pm
by NorthantsBen
NorthantsBen wrote:Ultra floor patch it comes in 5kg bags.
I mean feather it not patch it...
Posted: Sun Jun 21, 2015 10:28 am
by el_mag
Another quick question guys - Do I need to put a primer on the plywood before I put the Ultra-floor feather it?
Many thanks
Posted: Sun Jun 21, 2015 1:36 pm
by Wes
el_mag wrote:Another quick question guys - Do I need to put a primer on the plywood before I put the Ultra-floor feather it?
Many thanks
No.
El-mag, as with all such products, they'll be instructions on application on the side of the tub/bag..
