Rutland shopvac £30 appears to be in stock again
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
boxedin
Has thanked: 61 times
Been thanked: 319 times
Post by boxedin »
These users thanked the author boxedin for the post:
Argyll
Argyll
Has thanked: 1188 times
Been thanked: 583 times
Re: Rutland shopvac £30 appears to be in stock again
Post by Argyll »
Thanks. I've just ordered one.
Grumbledook
Has thanked: 1 time
Been thanked: 15 times
Post by Grumbledook »
I take it these don't turn on and off when you turn on the tool you're using?
Also seems a bit odd they picture their cyclone unit with this but in the description of the cyclone it states it isn't compatible with it.
Argyll
Post by Argyll »
I received mine today. The instructions are vague to say the least and there's little mention of the paper bag filter. When using it for dust extraction should I use the paper bag filter or not?
Grumbledook
Has thanked: 1 time
Looks like they've got them back in again. Anyone know the answers to the above questions?
Rorschach
Has thanked: 116 times
Been thanked: 1042 times
Post by Rorschach »
I am sure it could be adapted to work with the cyclone, my shop van didn't fit at first so I made up some adaptors of my own and now it works a treat.
Regarding dust bags, yes you probably want to use them if you know you are going to be producing a lot of fine dust such as sanding, don't use it for general cleaning as any bits of metal, screws etc, will puncture the bag usually.
As an aside if you have a cyclone you should not need to use the filter bag at all. I used mine to sand several walls and the cyclone captures almost all the dust with the pleated filter in the shop vac catching the rest, this was easily washed afterwards.
Return to “Bargain Tools”
