Vinyl over Floor Tiles
- Has thanked: 18 times
- Been thanked: 1 time
Hi
I don't know if I am in the right forum but I want to lay vinyl flooring over ceramic tiles that are already down.I was thinking of using a leveling screed please could you tell me what I would have to do before putting the screed down.
Thank you.
Thank you.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
Re: Vinyl over Floor Tiles
What type of tiles are they? Ceramic, porcelain, natural stone? Glossy glazed? Matt/satin finish?
In most cases a good degreasing and a prime first (whatever is recommended by the brand of SLC you use) is all that is needed but if they are highly glazed then you may want to think about keying the surface and applying a cement slurry first as a bridge.
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
I've done this in my downstairs toilet. I stuck 9mm ply down with grip fill to the tiles and had the vinyl fitted onto this. It's been fine in over a year.
- Has thanked: 820 times
- Been thanked: 3519 times
Yes you need a substrate as sheet vinyl will show the tile outlines as the vinyl settles in.
- Colour Republic
steviejoiner74 wrote:I've done this in my downstairs toilet. I stuck 9mm ply down with grip fill to the tiles and had the vinyl fitted onto this. It's been fine in over a year.
On a downstairs toilet where you are likely to be able to use just a
Single sheet of ply, I would have thought that works just fine but if you've got multiple sheets of ply in say a kitchen then I think you'd be better off SLC'ing
Don't why I just assumed this was a kitchen, shouldn't have really as the OP doesn't say.
- steviejoiner74
I only done it this way as I couldn't be bothered lifting the tiles and it's only to do me a few years tops before the room is redone.
Agreed in a bigger area it's not ideal to overboard with ply. SLC or even better remove all the tiles and make good the Existing floor.
Hi
Sorry I have not replied before but I have been out.I did think of ply board as I did this in my conservatory that had tiles and there is a few places that did not stick but I have just used U-Can leveling in the bathroom as I removed a bath and someone only put the floor tiles up to the edge and left a drop of about 5mm and this filled it in good and was wondering if it would cover all the floor.
